查看: 3606|回復: 1
求救 兩組程式結合
發表於 2013-12-9 16:22:50 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
---- SimpleMessageSystem 程式 ----
Control Arduino board functions with the following messages:
r a -> read analog pins
r d -> read digital pins
w d [pin] [value] -> write digital pin
w a [pin] [value] -> write analog pin
Base: Thomas Ouellet Fredericks
Additions: Alexandre Quessy
// Include de SimpleMessageSystem library
// REMOVE THE FOLLOWING LINE IF USING WIRING
#include <SimpleMessageSystem.h>
  // The following command initiates the serial port at 9600 baud. Please note this is VERY SLOW!!!!!!
  // I suggest you use higher speeds in your own code. You can go up to 115200 with the USB version, that's 12x faster
  Serial.begin(9600); //Baud set at 9600 for compatibility, CHANGE!
  if (messageBuild() > 0) { // Checks to see if the message is complete and erases any previous messages
    switch (messageGetChar()) { // Gets the first word as a character
    case 'r': // Read pins (analog or digital)
      readpins(); // Call the readpins function
      break; // Break from the switch
    case 'w': // Write pin
      writepin(); // Call the writepin function
void readpins(){ // Read pins (analog or digital)
  switch (messageGetChar()) { // Gets the next word as a character
    case 'd': // READ digital pins
    messageSendChar('d');  // Echo what is being read
    for (char i=2;i<14;i++) {
      messageSendInt(digitalRead(i)); // Read pins 2 to 13
    messageEnd(); // Terminate the message being sent
  case 'a': // READ analog pins
    messageSendChar('a');  // Echo what is being read
    for (char i=0;i<6;i++) {
      messageSendInt(analogRead(i)); // Read pins 0 to 5
void writepin() { // Write pin
  int pin;
  int state;
    case 'a' : // WRITE an analog pin
    pin = messageGetInt(); // Gets the next word as an integer
    state = messageGetInt(); // Gets the next word as an integer
    pinMode(pin, OUTPUT); //Sets the state of the pin to an output
    analogWrite(pin, state); //Sets the PWM of the pin
    // WRITE a digital pin
  case 'd' :
    pinMode(pin,OUTPUT);  //Sets the state of the pin to an output
    digitalWrite(pin,state);  //Sets the state of the pin HIGH (1) or LOW (0)
接收端:
#include<stdlib.h>
byte sensorValueA;                //宣告 BYTE變數  sensorValueA
int a;                             //宣告整數a
Serial.begin(9600);            //設定 第一組通道Serial的鮑率為9600
  if (Serial.available() > 0){        //如果感測到第一組通道有資料傳過來
sensorValueA = Serial.read();    //將讀到的資料放到sensorValueA
  a =int (sensorValueA);          //將sensorValueA 從BYTE轉換成int 放到a
Serial.print("No.1 = ");
Serial.print(a);
各位大大接收端與simplemessagesystem 結合
發表於 2013-12-9 16:52:24 | 只看該作者
這兩個程式有甚麼關係!?
沒關係的話COPY再一起就好了
SETUP 、LOOP的部分合成一個就行
但若有關係要詳述關連的部分才有辦法結合
GMT+8, 2026-7-5 12:03 , Processed in 0.209188 second(s), 8 queries , Apc On.
