查看: 2252|回復: 0
ARDUINO W5100問題
發表於 2016-11-8 21:51:34 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
專題目前學到W5100 要把#include <SPI.h>
#include <Ethernet.h>
// 指定網路卡 MAC 卡號
byte mac[] = {  0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
// 初始化 Ethernet client library
EthernetClient client;
  // 初始化序列埠
Serial.begin(115200);
  // 啟用 Ethernet 連線,預設會以 DHCP 取得 IP 位址
if (Ethernet.begin(mac) == 0) {
Serial.println("無法取得 IP 位址");
    // 無法取得 IP 位址,不做任何事情
for(;;)
  // 輸出 IP 位址
Serial.print("IP =");
Serial.println(Ethernet.localIP());
#include <SPI.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,2,100);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
// Open serial communications and wait for port to open:
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  // listen for incoming clients
  EthernetClient client = server.available();
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("HTTP/1.1 200 OK");
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
  client.println("Refresh: 5");  // refresh the page automatically every 5 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            int sensorReading = analogRead(analogChannel);
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(sensorReading);
            client.println("<br />");
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disonnected");
兩個結合一起 變成一個全自動的
只要從ARDUINO板上傳 就可直接在網頁上顯示IP
如下圖
請問各位大大程式要如何寫?
GMT+8, 2024-5-16 13:26 , Processed in 0.440823 second(s), 10 queries , Apc On.
