查看: 6142|回復: 1
賣 Bus Pirate 一片! 學習或驗證I2C, SPI, UART... 好幫手
發表於 2010-1-21 18:48:09 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
多買了一片,讓給這個論壇的朋友們!
http://store.fundamentallogic.co ... amp;products_id=474
The bus pirate can interface with most serial interfaces (SPI, I2C, RS232, JTAG, 1wire, etc) and is controlled by a simple serial terminal. If you have a bus pirate and a pc with a serial port, you can talk to most serial chips.
The kit includes all the necessary parts, including pre-programmed microcontroller, printed circuit board, integrated circuits, and connectors. You'll need to supply your own 6v-20v DC power supply and DB9 male to female serial cable.
可以直接與I2C 或 SPI等chip 溝通!  比寫code debug 快多了  :D
有3.3v, 5v output!
朋友價: 750含運!  (我買兩片含國際運費就要1600了)
發表於 2010-10-5 13:11:43 | 只看該作者
你好,我想購買
怎麼聯絡ㄋ
GMT+8, 2024-5-12 01:30 , Processed in 0.294991 second(s), 7 queries , Apc On.
