查看: 2583|回復: 0
如何讀取SD的圖片,傳送到伺服器
發表於 2019-3-18 22:51:28 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <SoftwareSerial.h>
#include <SD.h>
#define SD_CS 10
SoftwareSerial esp(4, 5);                   //RX,TX
String ssid = "6641k-16-14";                           //wifi name
String password = "062643462";                       //wifi password
String server = "120.114.132.69";                         // server name
void connectWifi()                           //wificonnection
  String cmd = "AT+CWJAP=\"" +ssid+"\",\"" + password + "\"";
  esp.println(cmd);
  delay(4000);
  if(esp.find("OK")){
    Serial.println(F("WIFI Connected!"));
  else {
  Serial.println(F("Cannot connect to wifi"));
  connectWifi();
void wifisetup()
  esp.println(F("AT"));
  esp.println(F("AT+CWMODE=3"));
  Serial.println(F("Wifi ready"));
  esp.begin(9600);
  pinMode(10, OUTPUT);
  Serial.println(F("Wifi Setup"));
  wifisetup();                         //wifi setup
  connectWifi();
  Serial.print(F("Initializing SD card..."));
  if (!SD.begin(SD_CS)) {
    Serial.println(F("failed!"));
    return;
    Serial.println(F("OK!"));
  test();
void test(){
  File webFile;
  char fileName[13] = "666.JPG";
  String cmd = "AT+CIPSTART=\"TCP\",\"" + server + "\",80";
  esp.println(cmd);
  delay(3000);
  if(esp.find("OK"))
    Serial.println(F("server found"));
    webFile = SD.open(fileName,FILE_READ);
    Serial.print(webFile);
    String post = F("POST /skin/upok.php HTTP/1.1\r\n");
     post += F("Host: 120.114.132.69\r\n");
     post += (F("Content-Type: multipart/form-data; boundary=WebKitFormBoundary7MA4YWxkTrZu0gW\r\n"));
     post += (F("Content-Length:"));
     post += webFile.size()+196;
     post += (F( "\r\n"));
     post += (F("----WebKitFormBoundary7MA4YWxkTrZu0gW"));
     post += (F("Content-Disposition: form-data"));
     post += (F("name=\"my_file\"; filename=\"666.JPG\"\r\n"));
     post += (F("Content-Type: image/jpeg\r\n"));
     post += (F("----WebKitFormBoundary7MA4YWxkTrZu0gW--\r\n"));
    Serial.print(post);
    String sendData = "AT+CIPSEND=" + String(post.length());
    Serial.println(sendData);
    esp.println(sendData);
    delay(6000);
    if (esp.find(">"))
      Serial.println(F("SENDING  data"));
       Serial.println(F("NOT SENDING"));
       esp.println(F("AT+CIPCLOSE"));
    Serial.println(F("server not found"));
  delay(10000);
有哪位高手知道如何讀取SD卡的圖片,然後傳到伺服器的程式碼,找了蠻多資料,跟圖片上傳相關的很少
GMT+8, 2024-4-29 04:46 , Processed in 0.197557 second(s), 7 queries , Apc On.
