查看: 9286|回復: 0
arduino 睡眠問題與SoftwareSerial.h的衝突
發表於 2020-11-6 14:26:04 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
大家好
目前使用UART 與sensor arduino 通訊 我想要使用watchdog 方式讓arduino 進入睡眠模式
但因為使用到#include <SoftwareSerial.h>而導致arduino 無法進入睡眠 想請問要如何更改
才能讓arduion 進入睡眠15分鐘並且醒來
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
#include "Oxygen.h"
#include <avr/sleep.h>
volatile int sleep_count = 0; // Keep track of how many sleep
const int sleep_total = 103; // ~ 15 min
SoftwareSerial mySerial(8, 9); // RX, TX pins on Ardunio
#define SampleNum 20
int co2 =0;
double multiplier = 10;// 1 for 2% =20000 PPM, 10 for 20% = 200,000 PPM
uint8_t buffer[25];
uint8_t ind =0;
uint8_t index =0;
int fill_buffer();  // function prototypes here
String format_output();
RTC_DS3231 rtc;
const int chipSelect = 4;
int checkstate = 0;
//analogReference(INTERNAL2v56);
void setup(void) {
//rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
deviceINIT();
watchdogOn(); // Turn on the watch dog timer.
mySerial.begin(9600); // Start serial communications with sensor
mySerial.println("M 6"); // send Mode for Z and z outputs
mySerial.println("K 1");  // set streaming mode
void loop(void) {
if (sleep_count % sleep_total == 0) {
// CODE TO BE EXECUTED PERIODICALLY
  Serial.println("wake!");
  String dataString = "";
  // read RTC
  DateTime now = rtc.now();
  dataString = String(now.year()) + "/" + String(now.month()) + "/" + String(now.day()) + " " + String(now.hour()) + ":" + String(now.minute()) + ":" + String(now.second()) + " ";
  // read O2
  float O2 = 0;
  O2 = O2_value();
  dataString += "O2 ";
  dataString += String(O2);
  dataString += " ";
  delay(500);
  // read CO2
  fill_buffer();
  index = 8;  // In ASCII buffer, filtered value is offset from raw by 8 bytes
  String CO2=format_output();
  dataString += "CO2 ";
  dataString += String(CO2);
   dataString += " ";
  delay(500);
  // write SD
  File dataFile = SD.open("Dlog.txt", FILE_WRITE);
  if (dataFile) {
    dataFile.println(dataString);
    dataFile.close();
    Serial.println(dataString);
  else {
    Serial.println("error opening Dlog.txt");
  Serial.println("go to sleep");
  // delay to print out serial
  delay(2900);
  // reset count
  sleep_count = 0;
goToSleep();
void goToSleep()
set_sleep_mode(SLEEP_MODE_PWR_DOWN); // Set sleep mode.
sleep_enable(); // Enable sleep mode.
sleep_mode(); // Enter sleep mode.
sleep_disable(); // Disable sleep mode after waking.
void watchdogOn() {
MCUSR = MCUSR & B11110111;
WDTCSR = WDTCSR | B00011000;
WDTCSR = B00100001;
WDTCSR = WDTCSR | B01000000;
ISR(WDT_vect)
sleep_count ++; // keep track of how many sleep cycles
void deviceINIT(){
  // SD module init
  Serial.print("Initializing SD card...");
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    return;
  Serial.println("card initialized.");
  //RTC init
  delay(3000); // wait for console opening
  if (! rtc.begin()) {
    Serial.println("Couldn't find RTC");
    while (1);
  if (rtc.lostPower()) {
    Serial.println("RTC lost power!");
  O2_value();
void StartTimeCorrect(){
    int c_time = (60-now.minute())%15;
    complement_delay(c_time);
    Serial.println("end wait");
    delay(100);
void delay1min(){
  delay(30000);
  delay(30000);
void complement_delay(int c){
  for (int i=0;i<c;i++){
    delay1min();
int fill_buffer(void){
// Fill buffer with sensor ascii data
ind = 0;
while(buffer[ind-1] != 0x0A){  // Read sensor and fill buffer up to 0XA = CR
  if(mySerial.available()){
    buffer[ind] = mySerial.read();
    ind++;
  // buffer() now filled with sensor ascii data
  // ind contains the number of characters loaded into buffer up to 0xA =  CR
  ind = ind -2; // decrement buffer to exactly match last numerical character
String format_output(){ // read buffer, extract 6 ASCII chars, convert to PPM and print
  int co2 =0;
  int index=8; double multiplier = 10;
  co2 = buffer[15-index]-0x30;
  co2 = co2+((buffer[14-index]-0x30)*10);
  co2 +=(buffer[13-index]-0x30)*100;
  co2 +=(buffer[12-index]-0x30)*1000;
  co2 +=(buffer[11-index]-0x30)*10000;
  return String(co2*multiplier/10000,4);
GMT+8, 2024-5-11 13:08 , Processed in 0.171582 second(s), 7 queries , Apc On.
