查看: 11303|回復: 1
a function-definition is not allowed here before '{' token" error
發表於 2020-12-11 21:10:16 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
請問我的程式裡括號的部分是錯在哪呢,一直找不到答案......
可以幫忙修改嗎
#include <DHT.h>
#include <DHT_U.h>
#include" DHT.h "
#define dhtPin 2 //Read DHT11 data
#define dhtType DHT11 // //Insert DHT11
#define FAN 8
#define HOT 9
#define PERIOD1 10 * 60 * 60 * 1000 //in a few units
#define PERIOD2 15 * 60 * 60 * 1000 //in millimeters
#define PERIOD3 25 * 60 * 60 * 1000
  // millis() returns unsigned long, so we will use it to track
  Unsigned longer lastTime = 0;
  Temperature control program
  Maintain 80 degrees for 10 minutes
  Maintain 70 degrees for 15 minutes
    Maintain 60 degrees in 25 minutes
    DHT dht (dhtPin, dhtType); //Initialize DHT sensor
  int stage = 0;
  Floating point t
    Serial.begin(9600);//Set the baud rate to 9600
    pinMode (FAN, OUTPUT);
    pinMode (heat, output);
    digitalWrite(FAN, LOW);
    digitalWrite(HOT, LOW);
    dht.begin(); //Start DHT
    lastTime = millis();
    Stage = 80;
  void up()
    if (stage >= t - 3)
      digitalWrite(FAN, HIGH);
    Otherwise (stage <= t - 3)
    other
  Invalid loop()
    t = dht.readTemperature();//Read the temperature in Celsius
    float f = dht.readTemperature(true);//Whether read the temperature in Fahrenheit
    (Isnan(h) || isnan(t) || isnan(f))
      Serial.println("Unable to read from DHT sensor!");
      return;
    unsigned long now = millis();
    if (now - lastTime >= PERIOD1) //every PERIOD count
      Stage = 80;
    Otherwise if (now - lastTime >= PERIOD2) //every PERIOD count is once
      Stage = 70;
    else if (now - lastTime >= PERIOD3) //every PERIOD count
      Stage = 60;
點評
海!外直播 cutt.us/q33 禁闻视频 v.ht/fccc 记者:暴雨村里有房子有倒的吗?老乡:没倒塌,拆迁办比洪水来得早。记者:地里庄稼被冲了吧? 老乡:真的没有!开发商也比洪水来得早,地早征走了。   發表於 2021-9-7 10:06
GMT+8, 2024-5-12 20:25 , Processed in 0.341948 second(s), 8 queries , Apc On.
