查看: 3077|回復: 0
請問哪裡是可以調整 servo轉動的地方
發表於 2011-10-12 16:15:10 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
// Includes
#include <avr/interrupt.h>
#include <avr/io.h>
#include <stdlib.h>
#include "oi.h"
//AVRlib includes
#include "global.h"
#include "a2d.h"
// Constants
#define RESET_SONG 0
#define START_SONG 1
#define BUMP_SONG  2
#define END_SONG   3
#define PORT_ON( port_letter, number )
port_letter |= (1<<number)
#define PORT_OFF( port_letter, number )
port_letter &= ~(1<<number)
#define PORT_ALL_ON( port_letter, number )
port_letter |= (number)
#define PORT_ALL_OFF( port_letter, number )
port_letter &= ~(number)
#define FLIP_PORT( port_letter, number )
port_letter ^= (1<<number)
#define PORT_IS_ON( port_letter, number )
( port_letter & (1<<number) )
#define PORT_IS_OFF( port_letter, number )
!( port_letter & (1<<number) )
// Global variables
volatile uint16_t timer_cnt = 0;
volatile uint8_t timer_on = 0;
volatile uint8_t sensors_flag = 0;
volatile uint8_t sensors_index = 0;
volatile uint8_t sensors_in[Sen6Size];
volatile uint8_t sensors[Sen6Size];
volatile int16_t distance = 0;
volatile int16_t angle = 0;
volatile uint16_t update_delay = 15;
volatile uint8_t range = 0;
unsigned int scan_thresh=0;
unsigned long int scan_angle=750;
void byteTx(uint8_t value);
void delayMs(uint16_t time_ms);
void delayAndUpdateSensors(unsigned int time_ms);
void initialize(void);
void powerOnRobot(void);
void baud(uint8_t baud_code);
void drive(int16_t velocity, int16_t radius);
void drive_distance(int16_t velocity, int16_t radius, int16_t distance_togo);
void drive_angle(int16_t velocity, int16_t radius, int16_t angle_togo);
uint16_t randomAngle(void);
void defineSongs(void);
void rotate_CCW(int16_t angle_tmp, int16_t velocity);
void rotate_CW(int16_t angle_tmp, int16_t velocity);
void straight(int16_t distance_tmp, int16_t velocity);
void stop(void);
void scan(unsigned int scan_thresh);
void servo_scan(unsigned long int speed);
void delay_cycles(unsigned long int cycles);
int main (void)
  uint8_t leds_cnt = 99;
  uint8_t leds_state = 0;
  uint8_t leds_on = 1;
  initialize();
  LEDBothOff;
  powerOnRobot();
  byteTx(CmdStart);
  baud(Baud28800);
  defineSongs();
  byteTx(CmdControl);
  byteTx(CmdFull);
  drive(0, RadStraight);
  byteTx(CmdPlay);
  byteTx(RESET_SONG);
  delayAndUpdateSensors(750);
  for(;;)
    if(++leds_cnt >= 100)
      leds_cnt = 0;
      leds_on = !leds_on;
      if(leds_on)
        byteTx(CmdLeds);
        byteTx(LEDsBoth);
        byteTx(128);
        byteTx(255);
        LEDBothOff;
        byteTx(CmdLeds);
        byteTx(0x00);
        byteTx(0);
        byteTx(0);
        LEDBothOn;
    delayAndUpdateSensors(10);
    if(UserButtonPressed)
      byteTx(CmdPlay);
      byteTx(START_SONG);
      delayAndUpdateSensors(2500);
      angle = 0;
  distance = 0;
      while(!(UserButtonPressed)
            && (!sensors[SenCliffL])
            && (!sensors[SenCliffFL])
            && (!sensors[SenCliffFR])
            && (!sensors[SenCliffR])
            && (!sensors[SenChAvailable]))
scan(30);
if (scan_angle > 840)
drive(100, RadCW);
else if (scan_angle < 660)t
drive(100, RadCCW);
if (a2dConvert8bit(1) > 50)
drive(-300, RadStraight);
drive(100, RadStraight);
        delayAndUpdateSensors(update_delay);
      // Stop driving
      // Play end song and wait
      delayAndUpdateSensors(500);
      byteTx(CmdPlay);
      byteTx(END_SONG);
      delayAndUpdateSensors(2000);
// Serial receive interrupt to store sensor values
SIGNAL(SIG_USART_RECV)
  uint8_t temp;
  temp = UDR0;
  if(sensors_flag)
    sensors_in[sensors_index++] = temp;
    if(sensors_index >= Sen6Size)
      sensors_flag = 0;
SIGNAL(SIG_OUTPUT_COMPARE1A)
  if(timer_cnt)
    timer_cnt--;
    timer_on = 0;
  while(!(UCSR0A & _BV(UDRE0))) ;
  UDR0 = value;
  timer_on = 1;
  timer_cnt = time_ms;
  while(timer_on) ;
void delayAndUpdateSensors(uint16_t time_ms)
  uint8_t temp;
  timer_on = 1;
  while(timer_on)
    if(!sensors_flag)
      for(temp = 0; temp < Sen6Size; temp++)
        sensors[temp] = sensors_in[temp];
      distance += (int)((sensors[SenDist1] << 8) | sensors[SenDist0]);
      angle += (int)((sensors[SenAng1] << 8) | sensors[SenAng0]);
      byteTx(CmdSensors);
      byteTx(6);
      sensors_index = 0;
      sensors_flag = 1;
  range=a2dConvert8bit(1);
  cli();
  // Set I/O pins
  DDRB = 0x12;
  PORTB = 0xCF;
  DDRC = 0x00;
  PORTC = 0x00;
  DDRD = 0xE6;
  PORTD = 0x7D;
  TCCR1A = 0x00;
  TCCR1B = (_BV(WGM12) | _BV(CS12));
  OCR1A = 71;
  TIMSK1 = _BV(OCIE1A);
  UBRR0 = 19;
  UCSR0B = (_BV(RXCIE0) | _BV(TXEN0) | _BV(RXEN0));
  UCSR0C = (_BV(UCSZ00) | _BV(UCSZ01));
  a2dInit();
  a2dSetPrescaler(ADC_PRESCALE_DIV32);
  a2dSetReference(ADC_REFERENCE_AVCC);
  sei();
  if(!RobotIsOn)
      while(!RobotIsOn)
          RobotPwrToggleLow;
          delayMs(500);
          RobotPwrToggleHigh;
          delayMs(100);
          RobotPwrToggleLow;
      delayMs(3000);
  if(baud_code <= 11)
    byteTx(CmdBaud);
    UCSR0A |= _BV(TXC0);
    byteTx(baud_code);
    while(!(UCSR0A & _BV(TXC0))) ;
    cli();
    if(baud_code == Baud115200)
      UBRR0 = Ubrr115200;
    else if(baud_code == Baud57600)
      UBRR0 = Ubrr57600;
    else if(baud_code == Baud38400)
      UBRR0 = Ubrr38400;
    else if(baud_code == Baud28800)
      UBRR0 = Ubrr28800;
    else if(baud_code == Baud19200)
      UBRR0 = Ubrr19200;
    else if(baud_code == Baud14400)
      UBRR0 = Ubrr14400;
    else if(baud_code == Baud9600)
      UBRR0 = Ubrr9600;
    else if(baud_code == Baud4800)
      UBRR0 = Ubrr4800;
    else if(baud_code == Baud2400)
      UBRR0 = Ubrr2400;
    else if(baud_code == Baud1200)
      UBRR0 = Ubrr1200;
    else if(baud_code == Baud600)
      UBRR0 = Ubrr600;
    else if(baud_code == Baud300)
      UBRR0 = Ubrr300;
    sei();
    delayMs(100);
  byteTx(CmdDrive);
  byteTx((uint8_t)((velocity >> 8) & 0x00FF));
  byteTx((uint8_t)(velocity & 0x00FF));
  byteTx((uint8_t)((radius >> 8) & 0x00FF));
  byteTx((uint8_t)(radius & 0x00FF));
// Define songs to be played later
  // Reset song
  byteTx(CmdSong);
  byteTx(RESET_SONG);
  byteTx(4);
  byteTx(60);
  byteTx(6);
  byteTx(72);
  byteTx(6);
  byteTx(84);
  byteTx(6);
  byteTx(96);
  byteTx(6);
  // Start song
  byteTx(CmdSong);
  byteTx(START_SONG);
  byteTx(6);
  byteTx(69);
  byteTx(18);
  byteTx(72);
  byteTx(12);
  byteTx(74);
  byteTx(12);
  byteTx(72);
  byteTx(12);
  byteTx(69);
  byteTx(12);
  byteTx(77);
  byteTx(24);
  // Bump song
  byteTx(CmdSong);
  byteTx(BUMP_SONG);
  byteTx(2);
  byteTx(74);
  byteTx(12);
  byteTx(59);
  byteTx(24);
  // End song
  byteTx(CmdSong);
  byteTx(END_SONG);
  byteTx(5);
  byteTx(77);
  byteTx(18);
  byteTx(74);
  byteTx(12);
  byteTx(72);
  byteTx(12);
  byteTx(69);
  byteTx(12);
  byteTx(65);
  byteTx(24);
drive(velocity, RadCCW);
while(angle<angle_tmp)
stop();
angle=angle-angle_tmp;/
drive(velocity, RadCW);
while((-angle)<angle_tmp)
stop();
drive(velocity, RadStraight);
while(distance<distance_tmp)
stop();
distance=distance-distance_tmp;
void stop(void)
if (a2dConvert8bit(1) > scan_thresh)
if (scan_angle>300)
scan_angle-=10;
if (scan_angle<=1200)
scan_angle+=10;
servo_scan(scan_angle);
while(cycles > 0)
cycles--;
PORT_ON(PORTB, 1);
delay_cycles(speed);
PORT_OFF(PORTB, 1);
請問這段程式碼 哪裡是可以調整servo調整的地方呢?
哈哈哈哈,因為我是新手 這裡這我看別人的程式碼的
想說直接學習別人的程式碼看看(我是利用創建irobot機器人)
想我我都沒有修改程式碼 , 但是我的servo無法帶著轉動我的scanner!
請問哪一段是可以修改的!
GMT+8, 2024-5-11 16:37 , Processed in 0.179976 second(s), 7 queries , Apc On.
