查看: 3525|回復: 1
ping超音波使用在avr上的問題
發表於 2011-11-9 01:48:48 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
我將ping超音波的信號角接至PORTB.3,程式如下
#include <mega16.h>
#include <alcd.h>
#include <delay.h>
unsigned long dis_cal(unsigned int timer);
void lcd_scan(unsigned long distance);
unsigned char x=0;
unsigned int pwm_1=0,timer;
double distance;
interrupt [TIM0_OVF] void timer0_ovf_isr(void)
  if(TCCR0==0x07)                               //00000111(計時由T0腳位輸入,正緣觸發)
          TCCR0=0x06;                           //令00000110(計時由T0腳位輸入,負緣觸發)
          timer=0;
          x=1;
  else if(TCCR0==0x06)                          //00000110(計時由T0腳位輸入,負緣觸發)
          TCCR0=0x07;                           //令00000111(計時由T0腳位輸入,正緣觸發)
          x=0;
      TCNT0=0xff;                               //令初值255
interrupt [TIM1_OVF] void timer1_ovf_isr(void)
     TCNT1H=0xff;
     TCNT1L=0xD8;
     pwm_1++;
     if(x==1)
       timer++;
     PORTB.3=(!PORTB.3);
void main(void)
    PORTB=0x08;
    DDRB=0x00;
    TCCR0=0x07;                                 //00000111(計時由T0腳位輸入,正緣觸發)
    TCNT0=0xff;                                 //計時器0為256
    TCCR1A=0x00;
    TCCR1B=0x01;                                //00000001(無分頻)
    TCNT1H=0x00;
    TCNT1L=0x00;
    TIMSK=0x05;
    ACSR=0x80;
    lcd_init(16);
    #asm("sei")
while (1)
       if(pwm_1>=0 && pwm_1<=500)
         PINB.3=1;
       else if(pwm_1>500 && pwm_1<=6000)
         if(pwm_1>5000)
              pwm_1=0;
             PINB.3=0;
             distance=dis_cal(timer);
             lcd_scan(distance);
      }//end while
}//end main
     unsigned long distance;
     float handle;
     handle=((10*timer)/2)*2257;
     distance=handle;
     return distance;
     lcd_clear();
     lcd_gotoxy(0,0);
     lcd_putsf("Test Distance:");
     lcd_gotoxy(0,1);
     lcd_putchar((distance/100%10)+0x30);
     lcd_gotoxy(1,1);
     lcd_putchar((distance/10%10)+0x30);
     lcd_gotoxy(2,1);
     lcd_putchar((distance%10)+0x30);
     lcd_gotoxy(3,1);
     lcd_putsf("cm");
但程式結果出來所量測距離在LCD上是不會改變的,不知原因在哪??
 樓主| 發表於 2011-11-9 01:51:15 | 只看該作者
剛程式有點問題,這個才是。
#include <mega16.h>
#include <alcd.h>
#include <delay.h>
unsigned char x=0;
double distance;
          timer=0;
          x=1;
          x=0;
     TCNT1H=0xff;
     TCNT1L=0xD8;
     pwm_1++;
     if(x==1)
       timer++;
     PORTB.3=(!PORTB.3);
void main(void)
    PORTB=0x08;
    DDRB=0x00;
    TCCR1A=0x00;
    TCNT1H=0x00;
    TCNT1L=0x00;
    TIMSK=0x05;
    ACSR=0x80;
    lcd_init(16);
    #asm("sei")
while (1)
         PINB.3=1;
         if(pwm_1>5000)
              pwm_1=0;
             PINB.3=0;
             lcd_scan(distance);
      }//end while
}//end main
     float handle;
     handle=(10*(float)timer)/58;
     distance=handle;
     return distance;
     lcd_clear();
     lcd_gotoxy(0,0);
     lcd_gotoxy(0,1);
     lcd_gotoxy(1,1);
     lcd_gotoxy(2,1);
     lcd_gotoxy(3,1);
     lcd_putsf("cm");
GMT+8, 2024-5-22 08:52 , Processed in 0.261323 second(s), 7 queries , Apc On.
