查看: 3699|回復: 1
為什麼這樣沒有輸出波形
發表於 2012-2-16 11:08:00 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <c8051f120.h>                 // SFR declarations
// Global Constants
//#define INTCLK       24500000          // Internal oscillator frequency in Hz
#define SYSCLK       22118400*9/2//49000000          // Output of PLL derived from (INTCLK*2)
#define TIMER_TICKS_PER_MS SYSCLK/TIMER_PRESCALER/1000
#define TIMER_PRESCALER
           100
#define LED_TOGGLE_RATE            100
#define AUX1     TIMER_TICKS_PER_MS*LED_TOGGLE_RATE
#define AUX2
-AUX1
#define AUX3
AUX2&0x00FF
#define AUX4
((AUX2&0xFF00)>>8)
#define TIMER0_RELOAD_HIGH         AUX4 //RELOAD VALUE FOR TIMER0 HIGH BYTE
#define TIMER0_RELOAD_LOW
   AUX3 //RELOAD VALUE FOR TIMER0 LOW BYTE
// Function Prototypes
void OSCILLATOR_Init (void);
void PORT_Init (void);
void PCA0_Init (void);
void Delay (int dly);
void motorContrl (int motor1,int motor2);
void Timer0_Init (void);
// Global Variables
unsigned int CEX0_Compare_Value;
unsigned int CEX1_Compare_Value;       // Holds current PCA compare value
unsigned int motor1=2200;
unsigned int motor2=6200;
sbit LED = P1^6;
   int i=0;
   SFRPAGE = CONFIG_PAGE;              // Set SFR page
   OSCXCN = 0x67;
   for (i=0;i<3000;i++);
   while((OSCXCN & 0x80) == 0);
   OSCXCN = 0x83;
   PLL0CN  = 0x04;                     // Set internal osc. as PLL source
   CCH0CN  &= ~0x20;
   SFRPAGE = LEGACY_PAGE;
   FLSCL   = 0xB0;                     // Set FLASH read time for 50MHz clk
   CCH0CN  |=0x20;
   PLL0CN  |=0x01;                     // Enable Power to PLL
   PLL0DIV = 0x02;                     // Set Pre-divide value to N (N = 1)
   PLL0FLT = 0x07;                     // Set the PLL filter register for
                                       // a reference clock from 19 - 30 MHz
                                       // and an output clock from 45 - 80 MHz
   PLL0MUL = 0x09;                     // Multiply SYSCLK by M (M = 2)
   for (i=0; i < 15; i++);
   // Wait at least 5us
   PLL0CN  |= 0x02;                    // Enable the PLL
   while(!(PLL0CN & 0x10) == 0);       // Wait until PLL frequency is locked
   CLKSEL  = 0x02;                     // Select PLL as SYSCLK source
   OSCICN  &=~0x80;
   char SFRPAGE_save = SFRPAGE;        // Save Current SFR page
   SFRPAGE = CONFIG_PAGE;              // Set SFR Page
   XBR0    = 0x98;                     // Route CEX0 to P0.0
   XBR1    = 0x00;
   XBR2    = 0x40;                     // Enable crossbar and weak pull-ups
   P0MDOUT |= 0x03;
   P1MDOUT |= 0xFF;                    // Set CEX0 (P0.0) to push-pull
   SFRPAGE = SFRPAGE_save;             // Restore SFR Page
// main() Routine
void main (void)
   // Disable watchdog timer
   WDTCN = 0xde;
   WDTCN = 0xad;
   PORT_Init ();                       // Initialize crossbar and GPIO
   OSCILLATOR_Init ();                 // Initialize oscillator
   PCA0_Init ();
   Timer0_Init();                      // Initialize PCA0
   EA = 1;
   IE =0x92;
   //SFRPAGE = PCA0_PAGE;
   while (1)
motorContrl(0,0);
Delay(1000);
    motorContrl(90,90);
Delay(1000);
motorContrl(180,180);
Delay(1000);
void motorContrl (int Angle1 ,int Angle2)
Angle1 = 4200 + Angle1 *22;
Angle2 = 4200 + Angle2 *25;
CEX0_Compare_Value = 65535 - Angle1;
CEX1_Compare_Value = 65535 - Angle2;
PCA0CPL0 = (CEX0_Compare_Value & 0x00FF);
    PCA0CPH0 = (CEX0_Compare_Value & 0xFF00)>>8;
PCA0CPL1 = (CEX1_Compare_Value & 0x00FF);
    PCA0CPH1 = (CEX1_Compare_Value & 0xFF00)>>8;
CR=1;
   char SFRPAGE_save = SFRPAGE;        // Save current SFR Page
   // Configure PCA time base; overflow interrupt disabled
   PCA0CN = 0x00;                      // Stop counter; clear all flags
   PCA0MD = 0x0A;                      // Use SYSCLK as time base
   PCA0CPM0 = 0xCB;                    // Module 0 = 16-bit PWM mode and
                                       // enable Module 0 Match and Interrupt
                                       // Flags
   PCA0CPM1 = 0xCB;                    // Module 0 = 16-bit PWM mode and
                                       // Flags
   // Configure initial PWM duty cycle = 50%
   CEX0_Compare_Value = 65536 - motor1;
   CEX1_Compare_Value = 65536 - motor2;
   PCA0CPL0=(CEX0_Compare_Value & 0x00FF);
   PCA0CPH0=(CEX0_Compare_Value & 0xFF00)>>8;
   PCA0CPL1=(CEX1_Compare_Value & 0x00FF);
   PCA0CPH1=(CEX1_Compare_Value & 0xFF00)>>8;
   // Start PCA counter
   CR = 1;
   EIE1 |= 0x0C;                       // Enable PCA interrupts
unsigned int i;
unsigned int j;
for(i=0;i<dly;i++)
for(j=0;j<dly;j++)
dly=dly;
void PCA0_ISR (void) interrupt 9
   CCF0 = 0;                           // Clear module 0 interrupt flag.
void Timer0_Init(void)
char SFRPAGE_SAVE = SFRPAGE;
SFRPAGE = TIMER01_PAGE;
TH0=TIMER0_RELOAD_HIGH;
    TL0=TIMER0_RELOAD_LOW;
TMOD = 0x01;
CKCON = 0x02;
ET0=1;
TCON = 0x10;
SFRPAGE = SFRPAGE_SAVE;
void Timer0_ISR (void) interrupt 1
LED = ~LED;
TH0 = TIMER0_RELOAD_HIGH;
TL0 = TIMER0_RELOAD_LOW;
// End Of File
0 error 0 warning
可以幫我看一下嗎
發表於 2012-3-1 15:51:46 | 只看該作者
SFR切換page的參數沒有看到定義
有可能參數沒正確設定
建議用Configuration Wizard先把設定值設好再寫程式
可以問一下為啥要用F120?
如果是小系統
用這個有點太over了
光是設定就累死........
GMT+8, 2024-5-14 16:10 , Processed in 0.175796 second(s), 8 queries , Apc On.
