查看: 9234|回復: 0
RFID writer
發表於 2012-8-10 01:56:18 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
你好上星期我向貴公司購買一組RFID Writer和tag卡
我是要用Arduino讀取RFID
我有去看官網的範例
但是就是讀不到也寫不進去
接腳也照上面的接了
請問這是什麼問題
程式:
//Code to write data to Parallax RFID reader/writer 28440 from Arduino
//Program writes to one of the 29 user-defined addresses (3-31) as define by whichSpace
//The four bytes to be written are defined by first, second, third, and fourth
//Coded by vgrhcp, adapted to arduino 1.0 by sebflippers
#include <SoftwareSerial.h>
#define RFID_WRITE 0x02
#define txPin 6
#define rxPin 8
#define whichSpace 4
#define first 1                 // first, second, thrid, and fourth are four arbitrary values which will be written to the RFID tag at address whichSpace
#define second 26
#define third 3
#define fourth 27
SoftwareSerial mySerial(rxPin, txPin);
  Serial.println("RFID Write Test");
  mySerial.begin(9600);
  pinMode(txPin, OUTPUT);
  pinMode(rxPin, INPUT);
void suppressAll()                                      //Keeps error code & the "write confirmation" codes from being printed in the serial monitor
    if(mySerial.available() > 0)
    { mySerial.read();
      suppressAll();
  int val;
  mySerial.print("!RW");
  mySerial.write(byte(RFID_WRITE));
  mySerial.write(byte(whichSpace));
  mySerial.write(byte(first));
  mySerial.write(byte(second));
  mySerial.write(byte(third));
  mySerial.write(byte(fourth));
if(mySerial.available() > 0) {
    val = mySerial.read();
    if (val == 1)                                        //If data was written successfully
      { Serial.println("Data written succesfully!");
        suppressAll();
    else suppressAll();                                  //If an error occured during writing, discard all data recieved from the RFID writer
delay(250);
GMT+8, 2026-10-6 03:03 , Processed in 0.190667 second(s), 7 queries , Apc On.
