查看: 8010|回復: 1
+Easy Bluetooth 藍芽模組的問題
發表於 2012-11-23 20:34:40 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最後由 a50292 於 2012-11-24 12:09 編輯
' {$STAMP BS2}
' {$PBASIC 2.5}
Ping            PIN     15
PingServo       PIN     14
LeftServo      PIN     13
RightServo      PIN     12
xx      PIN     11
BT_RX PIN 2
BT_TX PIN 0
BT_SPEED CON 84
tLeft VAR Word
tRight VAR Word
temp VAR Word
rawDist         VAR     Word
sweepcount      VAR     Word
x               VAR     Byte
pulseCount      VAR     Byte
counter VAR Word
inDistance VAR Word
Main:
FOR sweepcount = 350 TO 1150 STEP 100
  FOR x = 0 TO 5
    PULSOUT 15, sweepcount
    PAUSE 10
  NEXT
  GOSUB GetSonar
NEXT
FOR sweepcount = 950 TO 550 STEP 100
  FOR x = 0 TO 5
    PAUSE 10
  NEXT
  GOSUB GetSonar
NEXT
GOTO Main
GetSonar:
LOW 15
PULSOUT 15, 5
PULSIN 15, 1, rawDist
  IF (rawDist < 600) THEN
    IF (sweepcount < 750) THEN
      GOSUB Turn_Left
    ELSEIF (sweepcount > 750) THEN
      GOSUB Turn_Right
    ELSE
      GOSUB Back_Up
    ENDIF
  ELSE
    GOSUB Forward_Pulse
  ENDIF
RETURN
Forward_Pulse:
FOR pulsecount = 0 TO 5
HIGH 14
LOW 13
LOW 11
HIGH 12
PAUSE 20
NEXT
RETURN
Turn_Left:
FOR pulseCount = 0 TO 10
LOW 13
HIGH 14
PAUSE 20
NEXT
RETURN
Turn_Right:
LOW 12
HIGH 11
PAUSE 20
NEXT
RETURN
Back_Up:
FOR pulseCount = 0 TO 3
HIGH 13
LOW 14
LOW 11
HIGH 12
PAUSE 10
NEXT
FOR pulseCount = 0 TO 7
HIGH 13
LOW 14
LOW 11
HIGH 12
PAUSE 10
NEXT
RETURN
這是我還沒加上之前的 因為是要控制直流馬達跟感測器 所以用這樣寫 (1是往前 2是往後 不用左右)
不過加上藍芽的程式我摸不出來 希望能幫忙一下
playrobot 該用戶已被刪除
發表於 2013-1-14 17:01:59 | 只看該作者
抱歉, 您已經解決了嗎 ?
Easy Bluetooth Documentation v1.3 (.pdf)
RBT-001 Module - User Manual (.pdf)
Easy Bluetooth Software (.zip)
Easy Bluetooth Education Sample Code (.zip)
Easy Bluetooth Cell Phone Applet (.zip)
Easy Bluetooth Code For GUI (.bs2)
Easy Bluetooth AppNote (Bluetooth to Bluetooth Connection) (.pdf)
Easy Bluetoothx2demo (.zip)
GMT+8, 2025-12-22 18:28 , Processed in 0.203680 second(s), 8 queries , Apc On.
