查看: 5835|回復: 1
Launchpad+CD4017 8 Servo Control
發表於 2013-8-12 17:31:37 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
看這個版面有點冷,先來一些
Souece Code  main.c
* main.c MSP430G2553 Control 8 SERVO With CD4017
* CD4017 With 8 Servos
* connect Servo Signal to CD4017.Output1...Output8
#include <msp430g2553.h>
#define CPU_FQ 16 //16Mhz
#define CPU_F 16000000
#define SERVO_INIT 1000
void delay_us( double x)
unsigned long count=0;
  while(count++<=(x*CPU_FQ))
_nop();
void delay_ms(unsigned long x)
  while(count++<=(x*CPU_FQ*1000))
  _nop();
#define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
#define CLK_0       P1OUT &=~BIT0
#define CLK_1       P1OUT |= BIT0  // CD4017.CLK on P1.0
#define RST_0       P2OUT &=~BIT6
#define RST_1       P2OUT |= BIT6  // CD4017.RST on P2.6
unsigned int postion[8]={0,100,300,500,600,750,900,999};  //Servo Position from 0 to 999
unsigned char yn=0;
void delayus(long i)
TACCR0 = i;
TACTL = TASSEL_2+ID_3+ MC_1;  // SMCLK, div 8, up mode,TACTL = TASSEL_2 + MC_1 + ID_3+
TACCTL0 = CCIE;        // Enable interrupts for CCR0.
yn=1;
                                         // clear timer
__enable_interrupt();
while(yn==1);
_disable_interrupt();
void run_servo(void)
  unsigned char icount=0;
  RST_0;
  // to move CD4017 to Output 1
  CLK_1;
  delayus(1);
  CLK_0;
  while(icount<8)
delayus(SERVO_INIT+postion[icount++]);
CLK_1;
delay_us(1);
CLK_0;
  // to move CD4017 to Output 0
  CLK_1;
  delayus(1);
  CLK_0;
  delayus(9000);
  RST_1;
  //delay_us(1);
void main(void)
  unsigned int i,j;
  WDTCTL = WDTPW + WDTHOLD;//關閉看門狗
  BCSCTL1 = CALBC1_8MHZ;                    // Set DCO to 16MHz
  DCOCTL =  CALDCO_8MHZ; // enable P2.6 / P2.7 to Digial IO
  P1SEL = 0;// set P1 to digial IO
  P2SEL = 0;// set P2 to digial IO
  P1DIR = BIT0; // Set P1.0 to Outpot
  P2DIR = BIT6; //設定  P2.6  為輸出
  while(1)
      run_servo();
#pragma vector = TIMER0_A0_VECTOR
__interrupt void Timer0_A0 (void)
yn=0;
* This file is part of the MSP430 PWM example. It controls two servos on P1.6 and P2.2.
* Copyright (C) 2012 Stefan Wendler <sw@kaltpost.de>
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program.  If not, see <http://www.gnu.org/licenses/&gt;.
#include  <msp430.h>
void delay()
P1OUT ^= BIT0;
volatile unsigned long i;
i = 49999;
do (i--);
while (i != 0);
int main(void)
P1DIR |= BIT0;
// Internal LEDs P1.0 of Launchpad is output
    P1DIR |= BIT6;
// P1.6/TA0.1 is used for PWM, thus also an output -> servo 1
    P2DIR |= BIT2;
// P2.2/TA1.1 is used for PWM, thus also an output -> servo 2
P1OUT = 0;
// Clear all outputs P1
P2OUT = 0;
// Clear all outputs P2
P1SEL |= BIT6;                          // P1.6 select TA0.1 option
P2SEL |= BIT2;                          // P2.2 select TA1.1 option
// if SMCLK is about 1MHz (or 1000000Hz),
// and 1000ms are the equivalent of 1 Hz,
// then, by setting CCR0 to 20000 (1000000 / 1000 * 20)
// we get a period of 20ms
TA0CCR0 = 20000-1;                           // PWM Period TA0.1
TA1CCR0 = 20000-1;                           // PWM Period TA1.1
// setting 1500 is 1.5ms is 0deg. servo pos
TA0CCR1 = 1500;                            // CCR1 PWM duty cycle
TA1CCR1 = 1500;                            // CCR1 PWM duty cycle
TA0CCTL1 = OUTMOD_7;                       // CCR1 reset/set
TA0CTL   = TASSEL_2 + MC_1;                // SMCLK, up mode
TA1CCTL1 = OUTMOD_7;                       // CCR1 reset/set
TA1CTL   = TASSEL_2 + MC_1;                // SMCLK, up mode
// loop just blinks build in LEDs to show activity
for (;;)
delay();
TA0CCR1 = 1000;
TA1CCR1 = 2000;
delay();
TA0CCR1 = 1500;
TA1CCR1 = 1500;
delay();
TA0CCR1 = 2000;
TA1CCR1 = 1000;
delay();
TA0CCR1 = 1500;
TA1CCR1 = 1500;
 樓主| 發表於 2013-8-12 17:45:01 | 只看該作者
這是使用 CD4017 來驅動8個Servo,CD4017其實可以 Shift 10 個 PWN 訊號,但是上電時 Output 0 就 HI,所以這一腳不用,如果真的需要用到10個,可以多用一支 IO 來控制 CD4017的電源
來說一下 RC SERVO 的 PWM 訊號,一開始會有一段 1ms 的HI ,接下來的 HI 會決定其轉動的角度,0ms 為 0度, 0.5ms 為 90度,1ms 為 180度,接下來只少需要 18ms 的 Low ,整個 Period 為 20ms ,也就是 50Hz,這是一般Servo 的規格,當然有些可以更快一點
GMT+8, 2024-4-29 02:47 , Processed in 0.180223 second(s), 7 queries , Apc On.
