查看: 5515|回復: 2
如何用 wifi shield 做自走車的無線控制?
發表於 2014-7-9 01:36:27 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最後由 qqq12414 於 2014-7-9 01:38 編輯
最近剛入門 有許多問題還不太瞭解
手邊只有這塊wifi版:http://www.seeedstudio.com/depot/Wifi-Shield-p-1220.html
目前是接上飆機器人的ABB_CAR 想做無線控制
從網路上找到的範例修改後,我讓自走車連上手機的基地台後,用UDP廣播控制馬達動作
可是現在有一個問題,自走車必須接上電腦USB線,在手機端的廣播才有作用,一旦拔掉傳輸線就沒辦法控制
以下是我的程式碼,請問我的問題在哪邊呢?
#include <Arduino.h>
#include <SoftwareSerial.h>
#include "WiFly.h"
#include "Servo.h"
#define SSID      "AndroidAP"
#define KEY       ""
#define AUTH      WIFLY_AUTH_OPEN
#define UDP_HOST_IP        "192.168.43.44" // broadcast
#define UDP_REMOTE_PORT    8080
#define UDP_LOCAL_PORT     5555
// Pins' connection
// Arduino       WiFly
//  2    <---->    TX
//  3    <---->    RX
SoftwareSerial uart(2, 3);
WiFly wifly(uart);
int deg=90;
Servo servoLeft;
Servo servoRight;
Servo servoCamera;
void setupUDP(const char *host_ip, uint16_t remote_port, uint16_t local_port)
  char cmd[32];
  wifly.sendCommand("set w j 1\r", "AOK");   // enable auto join
  wifly.sendCommand("set i p 1\r", "AOK");
  snprintf(cmd, sizeof(cmd), "set i h %s\r", host_ip);
  wifly.sendCommand(cmd, "AOK");
  snprintf(cmd, sizeof(cmd), "set i r %d\r", remote_port);
  snprintf(cmd, sizeof(cmd), "set i l %d\r", local_port);
  wifly.sendCommand("save\r");
  wifly.sendCommand("reboot\r");
void forward(int time){
  servoLeft.writeMicroseconds(1700);
  servoRight.writeMicroseconds(1300);
  delay(time);
void backward(int time){
  servoLeft.writeMicroseconds(1300);
  servoRight.writeMicroseconds(1700);
  delay(time);
void turnLeft(int time){
  delay(time);
void turnRight(int time){
  delay(time);
void bestop(int time){
  servoLeft.writeMicroseconds(1500);
  servoRight.writeMicroseconds(1500);
  delay(time);
void camup(){
   if(deg == 180){
   servoCamera.write(deg);
   else {
     deg += 45;
void camdown(){
  if ( deg == 0){
  else {
    deg-=45;
  servoLeft.attach(13);
  servoRight.attach(12);
  servoCamera.attach(10);
  Serial.println("--------- WIFLY UDP --------");
  uart.begin(9600);     // WiFly UART Baud Rate: 9600
  wifly.reset();
  while (1) {
    Serial.println("Try to join " SSID );
    if (wifly.join(SSID, KEY, AUTH)) {
      Serial.println("Succeed to join " SSID);
      wifly.clear();
    } else {
      Serial.println("Failed to join " SSID);
      Serial.println("Wait 1 second and try again...");
  setupUDP(UDP_HOST_IP, UDP_REMOTE_PORT, UDP_REMOTE_PORT);
  wifly.sendCommand("set sys autoconn 1");
  wifly.clear();
  Serial.println("Succeed to create UDP");
unsigned int time_point = 0;
char receivedata;
while (wifly.available()) {
    receivedata = wifly.read();
    Serial.print(receivedata);
    if(receivedata==49 ){
      forward(20);
    else if(receivedata==50){
      backward(20);
    else if(receivedata==51){
      turnLeft(200);
    else if(receivedata==52){
      turnRight(200);
    else if(receivedata== 53){
      bestop(400);
    else if(receivedata== 54){
      camup();
    else if(receivedata== 55){
      camdown();
發表於 2014-7-11 03:28:29 | 只看該作者
回復 1# qqq12414
>>從網路上找到的範例修改後
  你意思是說,沒有經過修改的範例,自走車不須接上電腦USB線,在手機端的廣播也有作用,拔掉傳輸線一樣可以控制, 是嗎?
 樓主| 發表於 2014-7-11 21:28:54 | 只看該作者
本帖最後由 qqq12414 於 2014-7-11 21:31 編輯
回復 2# vegewell
找到問題了@@程式部分沒問題,後來發現是POWER不夠,所以拔掉USB線馬達會動不了
GMT+8, 2024-4-27 21:24 , Processed in 0.326844 second(s), 7 queries , Apc On.
