查看: 3926|回復: 0
HE3D mini 3D printer, lovely!
發表於 2014-10-27 14:51:01 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最後由 he3d 於 2014-10-27 14:52 編輯
Products Description:
Attention: This product is kit package ,need assemble .Thanks .
3d printer Motherboard:
melzi main chip 1284 p
3d printer stepper motor
A4982 chip
Output power:
24 v input  AC110-220 - v
Print the most large area:
140 x140x110mm
Physical size: 260 x280x280mm
Printing material:
ABS, PLA, 1.75 mm
in diameter.
Building surface: PCB heating bed, aluminum mesa, in order to reduce the complexity of the assembly, to ensure parts deformation.
nozzle diameter:
0.4mm (if you need 0.5mm, please left a message for us)
Precision standard:
0.1 mm
Resolution:
0.0125 mm
Construction speed:
1800 mm/min
Move speed:
1.2 mm/minute
Operation systerm support:
Linux  Mac  windows7
or later
XP
Printing software:
Repetier Host
or
Pronterface
Deposition rate: 33 cm/hour
Movement: X and Y and Z axis low friction bushing, X, Y is linear bearing. All welded electronics and built-in microSD card slot for independent printing. Enhanced set, improve the X and Y shaft assembly is convenient Ultra-low print noise, let you print more quiet!
Contain all parts for assembly
1, 1 pack hardware fittings
2, 5 NEMA14 stepper motors
3, heating bed 1 set of components
4, extrusion units 1 set
5, RP plastic parts 1 bag(total 42 piece. 2 metal coupling)
6, power supplier 1
7, 1 piece motherboard
Besides, we will give you 100g ABS , a set of special little tools and 1m high temperature tap as gifts . Thanks .
It is recommended that at the same time buy:
GMT+8, 2024-5-4 18:37 , Processed in 0.212097 second(s), 9 queries , Apc On.
