查看: 3912|回復: 0
heating bed delta 3 d printers
發表於 2014-10-27 14:59:52 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
Products Description:
Technical parameters:1, the printing technology: the accumulation of fused deposition molding (FDM)
3, overall dimensions: height:600 mm  width:320 mm   length:320 mm 4, the total weight: 10 kg (including packaging)
5, external frame: imported aluminum, steel (laser precision cutting)
6, extruder:remotely and  high-speed extrusion machine
7, the print head material: copper, aluminum, polyether ether ketone material forming
8, nozzle diameter: 0.4 mm (18, J - head hotend)
9 nozzle number: single nozzle
10 and the data format: STL
11, software: Repetier host
12, print range: 160 mm diameter     hight  230 mm
13, power input: AC110-220 - v
14, the power supply output: DC 12 v 7 a
15,print plate: high borosilicate glass    180 mm in diameter
16, synchronous belt wheel / 16 teeth, belt GT2
17, equipped with LCD screen
The performance parameters
1, print thickness of 0.05 mm to 4 mm
, 2, mechanical precision is 0.0125mm
3, the operating system, Windows/Mac/Linux
, 4, high-speed USB device interface or SD card
Shipping list:
1, 3 d DLT - 180 delta printer (fully assembled)
2, the power supply 1 (12 v 7 a)
3,USB cable 1
4, print the test material to 100 grams
About shipping:Most use EMS to send our way, if you have a specific way of logistics, please contact me
EMS is the fastest, we deliver goods orders after the payment, usually 1-2 days shipment
Other method of shipment takes 5 to 10 days, because the goods are to be transfer to the company If you need a heated bed, please click the image below
If you buy bulk, please click the following pictures
Customers who bought this product also purchased...New Products For October
GMT+8, 2024-5-2 08:51 , Processed in 0.190383 second(s), 9 queries , Apc On.
