查看: 4363|回復: 1
He3D-B140 3D Printer Completed assembly Huxley Reprap
發表於 2014-10-27 15:26:55 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
Products Description:
This product( He3D-B140) packed in wooden cases, there are a lot of plastic foam inside, can be shipped to all over the world, will not be damaged.
     Printing is the most widespread: 140 x140x110mm
nozzle diameter
0.4mm(if you want 0.5mm,please left message for us)
Dimension: 260 x280x280mm
     Printing material: ABS, PLA, diameter of 1.75 mm.
     Main: melzi
     Power supply: input AC110V - 220v, output: DC24V
     Heating bed building surface: PCB, aluminum countertops, to reduce
           the complexity of assembly, to ensure that the parts without deformation.
     Accuracy standards: 0.1 mm
     Resolution: 0.0125 mm
     The construction speed: 1800 mm/min
     Move speed: 1.2 mm/min
     Deposition rate: 33 cm/h
     Movement: X and Y axis and Z axis of the low friction liner, X and Y is linear bearing.
     All welded with built-in microSD card slot for the independent electronic printing.
     Enhanced calendar, and improve the assembly of X and Y axis is  convenient
     Ultra-low print noise, allows you to print more quiet!
     The machine shipment include: the machine packing size: 420x420x510mm weight 6.6 KG
     1, and a printer
     2, a switch power supply 24 v
Operation systerm support: Linux  Mac  windows7 or later XP.
For XP system, the printing software is Pronterface. For other systerms, the printing software is Repetier Host.
Packing size:500*400*400mm
It is recommended that at the same time buy:
 樓主| 發表於 2014-10-29 11:10:38 | 只看該作者
GMT+8, 2024-5-3 07:20 , Processed in 0.221808 second(s), 9 queries , Apc On.
