查看: 3567|回復: 0
he3d-i3 prusa i3 3d priner kit with LCD
發表於 2014-12-15 11:32:00 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
Products Description:
Model: he3d - i3
Selling forms: KIT  (Assemble it by ourselves!)
Please buy customers to wait for, will have inventory!More details and video in a few days will be
1,Frameead screw(   Stainless steel material)
     Structure:Acrylic sheet(Black or transparent)
2,Print Size:200*200*180mm(Max),
3,Layer thickness:0.1-0.4mm
4,SD Card off-line printing:Support
      LCD screen:There are  12864
5,XY axis positioning accuracy:0.0125mm,
6,Z axis positioning accuracy:0.004mm
7,Nozlle diameter:0.4mm(standard configuration) (You can choose   0.5)
8,Nozlle temperature:260oC (Max),
9,Platform temperature:120oC (adjustable)(MK3 )3 mm aluminum alloy heat the bed)
10,Platform material:aluminium plate
       Printing material:ABS,PLA
11,Material diameter:1.75mm
12,File format:STL,G-code,
13,Machine dimension:420(L)*455(W)* 380mm(H)
14,Package dimension:,460*500*300mm,
15,Power supply:DC 24V 400W Voltage input: vc110v - 220 - v
16,OS:XP,WIN7,MAC(
17,Host computer software:Repetier-Host
        Software language:English
18,Control panel:RAMPS 1.4
19,weighT:8.5KG
20,CD assembly manual and video tutorials
21,100 grams of printed materials PLA
skype:reprappro.cn
Email:support@reprap.cn
web:http://www.reprap.cn
jojo
GMT+8, 2024-4-29 11:02 , Processed in 0.245507 second(s), 9 queries , Apc On.
