查看: 4507|回復: 0
引入IRremote 的程式庫
發表於 2016-7-19 00:07:28 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
當我引入IRremote 的程式庫就變這樣,重抓也是請問有辦法解決嗎?
Arduino:1.6.9 (Windows 10), 板子:"Arduino/Genuino Uno"
java.io.IOException: Zip並不含有程式庫
        at processing.app.Base.handleAddLibrary(Base.java:2283)
        at processing.app.Base$6.actionPerformed(Base.java:1145)
        at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
        at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
        at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
        at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
        at javax.swing.AbstractButton.doClick(AbstractButton.java:376)
        at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833)
        at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877)
        at java.awt.Component.processMouseEvent(Component.java:6535)
        at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
        at java.awt.Component.processEvent(Component.java:6300)
        at java.awt.Container.processEvent(Container.java:2236)
        at java.awt.Component.dispatchEventImpl(Component.java:4891)
        at java.awt.Container.dispatchEventImpl(Container.java:2294)
        at java.awt.Component.dispatchEvent(Component.java:4713)
        at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888)
        at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
        at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
        at java.awt.Container.dispatchEventImpl(Container.java:2280)
        at java.awt.Window.dispatchEventImpl(Window.java:2750)
        at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
        at java.awt.EventQueue.access$500(EventQueue.java:97)
        at java.awt.EventQueue$3.run(EventQueue.java:709)
        at java.awt.EventQueue$3.run(EventQueue.java:703)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
        at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
        at java.awt.EventQueue$4.run(EventQueue.java:731)
        at java.awt.EventQueue$4.run(EventQueue.java:729)
        at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
        at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
        at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
        at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Zip並不含有程式庫
Zip並不含有程式庫
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
GMT+8, 2026-10-3 06:00 , Processed in 0.153263 second(s), 10 queries , Apc On.
