查看: 4044|回復: 0
新手求助
發表於 2016-12-5 22:54:52 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最後由 sam21408 於 2016-12-5 23:00 編輯
我看著書的解說,設計一個超音波避障車,結果車子只會前進幾秒,後退幾秒,右後轉,一直重複,請問我哪裡打錯,我是新手海請各位高手幫幫忙。
#include <Servo.h>
Servo servo;
const int ECHOPIN=2;
const int TRIGPIN=4;
const int negR=7;
const int posR=8;
const int negL=12;
const int posL=13;
const int pwmR=5;
const int pwmL=6;
const int Rspeed=150;
const int Lspeed=150;
const int rotSpeed=180;
unsigned long Rdistance;
unsigned long Ldistance;
unsigned long Cdistance;
  pinMode(posR,OUTPUT);
  pinMode(negR,OUTPUT);
  pinMode(posL,OUTPUT);
  pinMode(negL,OUTPUT);
  pinMode(TRIGPIN,OUTPUT);
  pinMode(ECHOPIN, INPUT);
  servo.attach(3);
  servo.write(90);
  servo.write(90);
  delay(500);
  Cdistance=ping(TRIGPIN );
  if(Cdistance<8)
    pause(0,0);
    servo.write(45);
    delay(500);
    Rdistance=ping(TRIGPIN);
    servo.write(135);
    delay(500);
    Ldistance=ping(TRIGPIN);
    servo.write(90);
    if(Rdistance<8 && Ldistance<8)
      back(Rspeed,Lspeed);
      delay(2000);
      right(rotSpeed,rotSpeed);
      delay(500);
      forward(Rspeed,Lspeed);
    else if(Rdistance>Ldistance)
      delay(500);
    else if(Ldistance>Rdistance)
      left(rotSpeed,rotSpeed);
      delay(500);
   int ping(int)
   unsigned long cm,duration;
   digitalWrite(TRIGPIN,HIGH);
   delayMicroseconds(2);
   delayMicroseconds(10);
   digitalWrite(TRIGPIN,LOW);
   duration=pulseIn(ECHOPIN,HIGH);
   cm=duration/29/2;
   return cm;
void forward(byte RmotorSpeed, byte LmotorSpeed)
    analogWrite(pwmR,RmotorSpeed);
    analogWrite(pwmL,LmotorSpeed);
    digitalWrite(posR,HIGH);
    digitalWrite(negR,LOW);
    digitalWrite(posL,LOW);
    digitalWrite(negL,HIGH);
void back(byte RmotorSpeed, byte LmotorSpeed)
    digitalWrite(posR,LOW);
    digitalWrite(negR,HIGH);
    digitalWrite(posL,HIGH);
    digitalWrite(negL,LOW);
void pause(byte RmotorSpeed, byte LmotorSpeed)
void right(byte RmotorSpeed, byte LmotorSpeed)
void left(byte RmotorSpeed, byte LmotorSpeed)
GMT+8, 2026-7-5 03:20 , Processed in 0.089849 second(s), 10 queries , Apc On.
