查看: 5201|回復: 1
請問一下 怎麼合併這兩個程式
發表於 2016-12-6 12:59:58 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
第一個是人體紅外線程式const int pir = 2;const int led =  13; int p = 0; void setup() {  Serial.begin(9600);  pinMode(pir, INPUT);       pinMode(led, OUTPUT);        }void loop(){  p = digitalRead(pir);  if (p == HIGH) {         digitalWrite(led, HIGH);     Serial.println("Detected");  }   else {    digitalWrite(led, LOW);     Serial.println("No One");  }  delay(1000);}第2個是HX711 重量感測程式#include "HX711.h"
int Weight = 0;
int Sec_Count = 0;
int Status = 0,Status_Pre = 1;
int Flag_Up = 0,Flag_Down = 0;void setup()
  pinMode(7, OUTPUT);
Init_Hx711();    //初始化HX711模組連接的IO設置 Serial.begin(9600);
Serial.print("Welcome to use!\n");
        Get_Maopi();  //獲取毛皮
delay(3000);
Get_Maopi();  //獲取毛皮
        Serial.print("Start!\n");
}void loop()
Weight = Get_Weight(); //計算放在感測器上的重物重量
        if(Weight <= 5)
          Status = 0;
          Status = 1;
        if(Status != Status_Pre)
          if(Status == 1 && Status_Pre == 0)
            Flag_Up = 1;
          if(Status == 0 && Status_Pre == 1)
            Flag_Down = 1;
          Status_Pre = Status;
        if(Flag_Up == 1)
          Flag_Up = 0;
          Sec_Count = 0;
        if(Status == 1 || Flag_Down == 1)
          Flag_Down = 0;
          Serial.print(Weight); //串口顯示重量
         Serial.print("g "); //顯示單位
          if(Status == 1)
            Serial.print(++Sec_Count);
            Serial.print(Sec_Count);
          Serial.print("s\n");
         if (Weight >=1000) {
     digitalWrite(7, HIGH) ;
  } else
     digitalWrite(7, LOW) ;
delay(1000);    //延時1s} 由於要做專題用,可是不知道為何合併起來顯示錯誤,是哪裡不能合併之類的嗎? 拜託各位大大幫忙了 謝謝
發表於 2016-12-8 01:57:02 | 只看該作者
把程式拆開先個別驗證
GMT+8, 2026-7-5 03:19 , Processed in 0.114553 second(s), 9 queries , Apc On.
