查看: 4071|回復: 2
2.4”TFT LCD的SD Card讀取問題
發表於 2017-3-30 22:48:18 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
想請問一下,我把2.4”TFT LCD 插在Arduino MEGA 2560G上,寫入測試程式,但測不到SD Card。可是同樣的方法在uno上就可以,求解?
以下是程式碼
#include <SPI.h>
#include <SD.h>
Sd2Card card;
SdVolume volume;
SdFile root;
const int chipSelect = 10;
  while (!Serial) {
  Serial.print("\nInitializing SD card...");
  if (!card.init(SPI_HALF_SPEED, chipSelect)) {
    Serial.println("initialization failed. Things to check:");
    Serial.println("* is a card inserted?");
    Serial.println("* is your wiring correct?");
    Serial.println("* did you change the chipSelect pin to match your shield or module?");
    return;
  } else {
    Serial.println("Wiring is correct and a card is present.");
到這裡就return了
發表於 2017-3-31 09:50:10 | 只看該作者
SD Card 是怎麼接的?
Arduino Mega 要接到 50, 51, and 52
其他機種(如UNO)則接 11, 12, and 13
 樓主| 發表於 2017-4-7 22:43:30 | 只看該作者
謝謝拉~我問完後有試成功囉~
GMT+8, 2026-7-5 01:21 , Processed in 0.202677 second(s), 7 queries , Apc On.
