查看: 6260|回復: 14
有關於遙控車跟超音波的合併
發表於 2017-10-11 17:58:45 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最後由 leo0983405269 於 2017-10-11 18:03 編輯
合併前
遙控車:
const int Motor_E2 = 11;
const int Motor_E1 = 10;
const int Motor_M1 = 12;
const int Motor_M2 = 13;
char val;  // variable to receive data from the serial port(bluetooth)
  // Start serial communication at 9600
  pinMode(Motor_M1, OUTPUT);
  pinMode(Motor_M2, OUTPUT);
  if(Serial.available()>0)
    val = Serial.read();
    switch(val)
      case 'f':   // car forward
                forward(0, 255);
      case 'd':   // car backward
                backward(0, 255);
      case 'l':   // car turn left
                left(0, 255);
      case 'r':   // car turn right
                right(0, 255);
      case 's':   // car stop
                motorstop(0, 0);
void motorstop(byte flag, byte motorspeed)
  Serial.println("Stop!");
  digitalWrite( Motor_E1, motorspeed);
  digitalWrite( Motor_E2, motorspeed);
void forward(byte flag, byte motorspeed)
  Serial.println("Forward!");
  digitalWrite( Motor_M1, HIGH);
  digitalWrite( Motor_M2, HIGH);
  analogWrite( Motor_E1, 200);
  analogWrite( Motor_E2, 200);
void backward(byte flag, byte motorspeed)
  Serial.println("Backward!");
  digitalWrite( Motor_M1, LOW);
  digitalWrite( Motor_M2, LOW);
void right(byte flag, byte motorspeed)
  Serial.println("Turn Right! ");
  analogWrite( Motor_E1, 50);
  analogWrite( Motor_E2, 0);
void left(byte flag, byte motorspeed)
  Serial.println("Turn Left!");
  analogWrite( Motor_E1, 0);
  analogWrite( Motor_E2, 50);
超音波:
#include <SoftwareSerial.h> //Arduino I2C library
const int trig =  8; //define Arduino pin
const int echo =  7;
const int TX   = 1;
const int RX   = 0;
const int delay_time = 1000; //delay 1000 ms for every measurment
SoftwareSerial BT(RX, TX);
//set Bluetooth RX (-> pin TX of Bluetooth Module), TX (-> pin RX of Bluetooth Module)
  //Serial.begin(9600); //set baud rate of Serial Monitor
  BT.begin(9600); //set baud rate of Bluetooth
  pinMode(trig, OUTPUT); //set trigger pin to OUTPUT (-> pin trig of Ultrasonic Sensor)
  pinMode(echo, INPUT); //set echo pin to INPUT (-> pin echo of Ultrasonic Sensor)
  //Serial.println("Start!!!");
  float duration; //duration to record the time of every back and forth
  float distance;
  digitalWrite(trig, HIGH); //trigger sona for 1 ms
  delayMicroseconds(1000);
  digitalWrite(trig, LOW);
  duration = pulseIn(echo, HIGH);
  //use pulseIn() function to get the time of pin echo from HIGH to LOW, unit=microseconds
  distance = (duration / 2) * 0.034;
  //distance = ( half of time of back and forth )x( wave velocity(use 0.034 cm per microsecond) )
  //Serial.print("Distance ="); //show result on Serial Monitor
  //Serial.print(distance);
  //Serial.println("cm");
  delay(delay_time);
  int sendData = (int) (distance * 100); //times 100 and convert disance to integer
  byte packet[3];
  packet[0] = 97; //key send to phone
  packet[1] = sendData / 256; //divides sendData to two 1 byte packets
  packet[2] = sendData % 256;
  if(BT.available() > 0) //check BT is succeed
    if(BT.read() == 97) //check recieve key from phone
      Serial.println("succeed!");
      for(int i = 0; i < 3; i++)
        BT.write(packet); //send packet to phone
上次新手大大提供把serial//掉我就直接沒在合併上面放進去了
合併後
const int echo =  7;
const int TX   = 1;
const int RX   = 0;
  float distance;
  byte packet[3];
  if(BT.available()>0)
    val = BT.read();
    switch(val)
                forward(0, 255);
                backward(0, 255);
                left(0, 255);
                right(0, 255);
                motorstop(0, 0);
請問是哪裡合錯了,兩個功能都出不來
編譯過是沒有錯誤
我現在有點擔心因為手機控制遙控車是 手機對車子  超音波的值是模組對手機
這樣會不會衝突導致沒辦法成功
還是我手機程式沒寫好,不好意思傷害幫忙的人的眼睛了。
如果有單獨遙控車或超音波的問題可以私訊我,我能力範圍內大家一起討論感謝
發表於 2017-10-11 20:28:47 來自手機 | 只看該作者
本帖最後由 超新手 於 2017-10-12 08:19 編輯
1.serial 沒有完全拿掉
2.bt.available沒有整合在一起
應該把 case 97: 整合進去
3.雖然結果相同
但是最好的做法是
把 bt 的部份都改成 serial
也就是拿掉// SoftwareSerial BT(RX, TX);
然後把所有的 BT 改成 Serial
用硬體 uart 取代軟體 uart, 速度較快
當初沒注意到這一點
 樓主| 發表於 2017-10-16 16:41:25 | 只看該作者
本帖最後由 leo0983405269 於 2017-10-16 16:55 編輯
我先在改改看   請問你說把BT改成Serial
可是不是要把serial都要拿掉嗎?
如果把有關SOFTWARE拿掉  那#include <SoftwareSerial.h> //Arduino I2C library也把它拿掉?
 樓主| 發表於 2017-10-16 17:06:47 | 只看該作者
本帖最後由 leo0983405269 於 2017-10-16 17:19 編輯
const int echo =  7;
const int TX   = 1;
const int RX   = 0;
  Serial.begin(9600); //set baud rate of Bluetooth
  float distance;
  byte packet[3];
    switch(val)
      case 'q'://測距離
                forward(0, 255);
                backward(0, 255);
                left(0, 255);
                right(0, 255);
                motorstop(0, 0);
如果照著我的理解  是修改成這樣嗎
        Serial.write(packet); //send packet to phone
這一段要放在哪裡?
還有這樣原本的TX,RX 不用設定了嗎?
我記得原本遙控車就沒有寫到關於TX跟RX腳位了
發表於 2017-10-16 17:22:58 | 只看該作者
本帖最後由 超新手 於 2017-10-16 17:24 編輯
1. Serial 要拿掉的是DEBUG 部份, 像(應該有五個吧?)
這些程式都是給人看的, 它會干擾APP讀值
2. 加到 case 中
    switch(val)
      case 'a':
其中的 97 , 就是 'a', 也就是 0x61
3. 那個 case 'q' 你沒寫程式,
 樓主| 發表於 2017-10-16 17:37:10 | 只看該作者
還是一開始的const int TX =1;
                   const int RX =0;
就設定了
但是如果只有遙控車的話我沒在裡面找到有關藍芽的腳位設定
 樓主| 發表於 2017-10-16 17:54:09 | 只看該作者
本帖最後由 leo0983405269 於 2017-10-16 18:00 編輯
超新手 發表於 2017-10-16 17:22
Serial.print ...
q  就是我把97改成英文字
我有在論壇找到前人的問題
如果打'97'好像不會變顏色
所以我改成q
如果把
    switch(val)
      case 'q':   //測距離
                forward(0, 255);
                backward(0, 255);
                left(0, 255);
                right(0, 255);
                motorstop(0, 0);
會出現call of overladed write(byte [3])' is ambiguous  調用write(byte [3])'是不明確的
是不應該write嗎?
 樓主| 發表於 2017-10-16 18:04:30 | 只看該作者
本帖最後由 leo0983405269 於 2017-10-16 18:07 編輯
所以干擾讀值得是 Serial.println這種的
                           Serial.begin是要留下來跟藍芽連線的
發表於 2017-10-16 20:01:32 | 只看該作者
本帖最後由 超新手 於 2017-10-17 12:50 編輯
1. 必須指定藍芽鮑率
所以 Serial.begin(9600); 不能拿掉
2. 97 是數字, 是 a 的 ASCII CODE(十進位)
所以,不能加引號,字元才要加
case 97:
等於
case 0x61:
等於
case 'a':
三種寫法是相同的, 它是數字, 不會變色也是正常的
但你要改成 'a' 而不是 'q'
不然 APP 那端也要一起改
3. 應該是
        Serial.write(packet[ i]);
不是我寫錯,而是這個論壇的 bug
看看你自己貼的這幾行就知道了
貼出的程式會被論壇改掉
 樓主| 發表於 2017-10-17 17:28:01 | 只看該作者
可以遙控車子側距離了    真的很感謝  已經卡住很久了
只是好像會有點延遲   比如手機端按往前  有時候要多按幾下  是因為測距離送出來的訊號跟遙控車送出來的訊號撞到了嗎?
那如果還想要加入溫度跟溼度的感應  會送更多訊號 這樣是不是會有更大的延遲?
發表於 2017-10-17 18:04:32 | 只看該作者
本帖最後由 超新手 於 2017-10-17 18:26 編輯
延遲可能是因為
1. APP 端 clock1 的速度太快
時間可以調長一點,
2. 你加了 delay(1000);
    所以你按再快, sonar 和 motor 也是一秒處理一次
    這個值可以縮短些
3. pulseIn(pin, value)
沒設timeout 時間, 所以一旦沒收到超音波
它"有機會"會卡住一秒鐘的時間
4. 可以把
改成
while(Serial.available()>0)
讓它一次就把資料處理完, 不會卡一大堆資料,
一秒(或很久)才處理一次
可能要自己改看看才知道為什麼
 樓主| 發表於 2017-10-17 19:05:16 | 只看該作者
好  我在改改看  感恩
 樓主| 發表於 2017-10-17 19:31:18 | 只看該作者
如果要在多新的感應器 就造著超音波合併的方法然後在appinventor2在拉clock就可以了嗎?
還是要寫在同一個clock裡面阿?
發表於 2017-10-18 08:28:47 | 只看該作者
寫在同一個即可, 也比較單純
 樓主| 發表於 2017-10-18 15:57:39 | 只看該作者
好  等我買元件來嘗試 謝謝你
GMT+8, 2026-7-5 05:34 , Processed in 0.187721 second(s), 7 queries , Apc On.
