查看: 4535|回復: 0
[馬達問題MG-995][atmega32控制問題]我是新手!幫解
發表於 2009-6-16 22:26:40 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
我是一個新手,請教各位大大幫忙我
請問各位專家!!
1) 為什麼我的SERVO MG-995只可以轉60度而不可轉180度?
2) 我打算用atmega32控制8個 SERVO, 下面的是我的CODE, 但是不知道為什麼 channel 0,1 沒有轉而只停在140度, 其他channel 就沒問題停在90度.
     code:
// up to 8 servos on portB sequentially controlled
// mega32
// 8 MHz
#include <avr/io.h>
#include <util/delay.h>
#include <avr/interrupt.h>
// initial pulse times in us for servo 0, 1, 2...(last value is a synchro gap)
unsigned int servo[9] = {1500, 1500, 1500, 1500, 1500, 1500, 1500, 1500, 6000};
volatile unsigned char servo_num = 0;
ISR(TIMER1_COMPA_vect)
   PORTD = (1<<servo_num);
   OCR1A  = servo[servo_num];
   servo_num++;
   servo_num %= 9;                 // if servo_num = 9 then servo_num = 0;
int main (void)
      DDRD = 255;                        // portb output
      TCCR1B |= (1<<WGM12) | (1<<CS11);  // pwm mode 4, prescale 8
      TIMSK |= (1<<OCIE1A);             // enable T1_compareA interrupt
      sei();
      for(;;)  // test
         servo[0] = 1000;          // servos 0 and 1 left
         servo[1] = 1000;
         _delay_ms(5000);
         servo[0] = 1500;          // servos 0 and 1 center
         servo[1] = 1500;
         _delay_ms(5000);
         servo[0] = 2000;          // servos 0 and 1 right
         servo[1] = 2000;
         _delay_ms(5000);
}//main
感謝啦!
GMT+8, 2026-7-8 23:29 , Processed in 0.198752 second(s), 8 queries , Apc On.
