查看: 9939|回復: 2
the best and cheapest mciro servo
發表於 2009-8-5 18:03:34 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
the best and cheapestmicro servo
so many good mciro servo for you to choose.
Believe you thoes micro servo can help you DIY best robot
 樓主| 發表於 2009-8-5 18:06:18 | 只看該作者
9g Metal Gear ServoPackage: One polybag one piece
Description: 0.12sec/60owith torque 1.3kg-cm(4.8V) wire: 18cm Metal Gear Servo
Feature:   Futaba, JR, Sanwa and Hitec compatible.
Important Notes:
1、  Specify the connector type when you purchase the servo.
2、  Refer to the figure when installing the servo accessories.
3、  For engine powered airplanes and boats, rubber must be used to reduce vibration.
4、  Please choose correct model for your application.
5、  Torque over-loaded will damage the servo's mechanism-.
6、  Keep the servo clean and away from dust, corrosive gas and humid air.
 樓主| 發表於 2009-8-5 18:08:19 | 只看該作者
16gStandard Analog Servo
Description: 16.0g with torque1.3kg-cm (4.8V) 2.0kg-cm (6.0V); wire: 18cm Standard Servo.
Important Notes:
GMT+8, 2026-7-5 11:31 , Processed in 0.164425 second(s), 8 queries , Apc On.
