查看: 4766|回復: 1
距離感測器和TM1637七段顯示器整合問題
發表於 2018-4-24 15:22:22 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
目前想要做用距離感測器
然後把數據顯示在七段顯示器上面
一直卡在Arduino開發板編譯錯誤
希望各位大大幫忙看是哪裡寫錯
(設這是原始檔)
#include <Arduino.h>
#include <TM1637Display.h>
#define CLK 2 // connect CLK to pin 2
#define DIO 3 // connect DIO to pin 3
#define TEST_DELAY 100
uint8_t blank[] = { 0x0, 0x0, 0x0, 0x0 };
TM1637Display display( CLK, DIO );
Serial.begin(9600); // Use Serial Monitor window
pinMode(A0,INPUT); // Connect sensor to analog pin A0
int sensorValue;
int distance;
int number;
int count = 0;
unsigned long time=0;
const byte num[10]=
{ B11000000,B11111001,B10100100,B10110000,B10011001,
B10010010,B10000010,B11111000,B10000000,B10010000};
const int seg[]={2,3,4,5,6,7,8,9};
const int digit[]={10,11,12,13};
display.setBrightness(0x0f);
sensorValue = analogRead(0);
if(sensorValue>=280&&sensorValue<=620) // If sensorValue between 280 ~ 620 ,will be touch off
   distance = 28250 / ( sensorValue - 229.5 );
   long int averaging = 0;
   //儲存10次距離數據
   for(int i = 0 ; i<2 ; i++ ) //sampimg 10 time within 1 seconds
    averaging = averaging + distance;
    delay(100);
   //得到距離數據之平均值
   distance = averaging / 2;
  Serial.print("Distance: ");
  display.setSegments(blank);
  int dis = distance();
  display.showNumberDec(dis , false , 3 , 1);
  Serial.print(distance);
  Serial.println("cm");
   averaging = 0;
  //重置紅外線感測器之數值為0
  delay(1500);
  //Wait another 1.5 second for the next read
  //延遲1.5秒
  delay(500);  //Wait another 1/2 second for the next read
發表於 2018-4-24 16:31:26 | 只看該作者
int sensorValue;
int distance;
int number;
int count = 0;
unsigned long time = 0;
const byte num[10] =
{ B11000000, B11111001, B10100100, B10110000, B10011001,
  B10010010, B10000010, B11111000, B10000000, B10010000
const int seg[] = {2, 3, 4, 5, 6, 7, 8, 9};
const int digit[] = {10, 11, 12, 13};
  pinMode(A0, INPUT); // Connect sensor to analog pin A0
  if (sensorValue >= 280 && sensorValue <= 620) // If sensorValue between 280 ~ 620 ,will be touch off
    //儲存10次距離數據
    for (int i = 0 ; i < 2 ; i++ ) //sampimg 10 time within 1 seconds
      delay(100);
    //得到距離數據之平均值
    int dis = distance;
    averaging = 0;
    //重置紅外線感測器之數值為0
    delay(1500);
    //延遲1.5秒
GMT+8, 2026-10-3 08:46 , Processed in 0.221413 second(s), 6 queries , Apc On.
