查看: 3962|回復: 1
想請問有關陣列的問題
發表於 2018-5-25 14:40:01 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
大家好目前在做陣列的研究,遇到了一些麻煩,在關於陣列要編譯時,沒辦法編譯,想請問大家那裡有問題 謝謝
#include <Wire.h>
#include <Adafruit_AMG88xx.h>
Adafruit_AMG88xx amg;
float pixels[AMG88xx_PIXEL_ARRAY_SIZE];
float pixels[8][8];
    Serial.begin(115200);
    bool status;
    status = amg.begin();
    if (!status) {}
    delay(100);
    amg.readPixels(pixels);
    for (int i=1; i<=AMG88xx_PIXEL_ARRAY_SIZE; i++)
        Serial.print('C');
        Serial.print(pixels[i-1]);
        while (Serial.available()<=0) {}
        Serial.read();
   amg.readPixels(&pixels[0][0]);
  //第一列
  Serial.print("ab");
  Serial.print(abs(pixels[0][0] - pixels[0][0]));               Serial.print("ab");
  Serial.print(abs(pixels[0][0] - pixels[0][1])/sqrt(2),2);     Serial.print("ab");
  Serial.print(abs(pixels[0][0] - pixels[0][1]));               Serial.print("ab");
  Serial.print(abs(pixels[0][0] - pixels[1][1])/sqrt(2),2);     Serial.print("ab");
  Serial.print(abs(pixels[0][0] - pixels[1][0]));               Serial.print("ab");
  Serial.print(abs(pixels[0][0] - pixels[1][0])/sqrt(2),2);     Serial.print("ab");
  Serial.print(abs(pixels[0][0] - pixels[0][0])/sqrt(2),2);     Serial.print("ab");
  for (int i = 0; i < 1; i++) {
  for (int j = 1; j < 7; j++) {
  Serial.print("ab");
  Serial.print(abs(pixels[i][j] - pixels[i][j]));               Serial.print("ab");
  Serial.print(abs(pixels[i][j] - pixels[i][j+1])/sqrt(2),2);   Serial.print("ab");
  Serial.print(abs(pixels[i][j] - pixels[i][j+1]));             Serial.print("ab");
  Serial.print(abs(pixels[i][j] - pixels[i+1][j+1])/sqrt(2),2); Serial.print("ab");
  Serial.print(abs(pixels[i][j] - pixels[i+1][j]));             Serial.print("ab");
  Serial.print(abs(pixels[i][j] - pixels[i+1][j-1])/sqrt(2),2); Serial.print("ab");
  Serial.print(abs(pixels[i][j] - pixels[i][j-1]));             Serial.print("ab");
  Serial.print(abs(pixels[i][j] - pixels[i][j-1])/sqrt(2),2);   Serial.print("ab");
  Serial.print("ab");
  Serial.print(abs(pixels[0][7] - pixels[0][7]));               Serial.print("ab");
  Serial.print(abs(pixels[0][7] - pixels[0][7])/sqrt(2),2);     Serial.print("ab");
  Serial.print(abs(pixels[0][7] - pixels[1][7])/sqrt(2),2);     Serial.print("ab");
  Serial.print(abs(pixels[0][7] - pixels[1][6]));               Serial.print("ab");
  Serial.print(abs(pixels[0][7] - pixels[0][6]));               Serial.print("ab");
  Serial.print(abs(pixels[0][7] - pixels[0][6])/sqrt(2),2);     Serial.print("ab");
發表於 2018-5-25 14:55:15 | 只看該作者
本帖最後由 超新手 於 2018-5-25 14:56 編輯
兩個不同的陣列, 但名稱一樣
一個是一維陣列, 另一個是二維陣列
float pixels[8][8];
去掉其中一個即可,
當然和它相應的程式也要一併拿掉
GMT+8, 2026-7-5 01:19 , Processed in 0.719935 second(s), 7 queries , Apc On.
