查看: 4754|回復: 1
IC2_address was not declared in this scope
發表於 2018-9-17 14:06:41 來自手機 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
// zoomkat's meta refresh data frame test page 5/25/13
// use ‭http://192.168.1.102:84‬ in your brouser for main page
// ‭http://192.168.1.102:84/data‬ static data page
// ‭http://192.168.1.102:84/datastart‬ meta refresh data page
// for use with W5100 based ethernet shields
// set the refresh rate to 0 for fastest update
// use STOP for single data updates
#include <SPI.h>
#include <Ethernet.h>
#include <Wire.h>
const int analogInPin0 = A0;
const int analogInPin1 = A1;
const int analogInPin2 = A2;
const int analogInPin3 = A3;
const int analogInPin4 = A4;
const int analogInPin5 = A5;
int X0, X1, Y0, Y1, Z1, Z0;
float X,Y,Z;
int sensorRead = 0;
int newdata = 0;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // arduino ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
unsigned long int x=0; //set refresh counter to 0
String readString;
void setup(){
    // disable SD SPI if memory card in the uSD slot
    pinMode(A2,INPUT);
    Wire.begin();  //初始化 I2C
    setReg(0x2D, 0xA); // (打開電源, 設定輸出資料速度為 100 Hz)
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  server.begin();
  Serial.println("meta refresh data frame test 5/25/13"); // so I can keep track of what is loaded
void setReg(int reg, int data){
    Wire.beginTransmission(I2C_Address);
    Wire.write(reg); // 指定佔存器
    Wire.write(data); // 寫入資料
    Wire.endTransmission();
/* setReg(reg,data):寫入佔存器
* 參數:
*     reg → 指定佔存器位址
*     data → 要寫入的資料
int getData(int reg){
    Wire.write(reg);
    Wire.requestFrom(I2C_Address,1);
    if(Wire.available()<=1){
        return Wire.read();
/* getData(reg):取得佔存器裡的資料
* 參數:reg → 佔存器位址
void loop(){
  X0 = getData(0x32); // 取得 X 軸 低位元資料
    X1 = getData(0x33); // 取得 X 軸 高位元資料
    X = ((X1 << 8)  + X0) / 256.0;
    Y0 = getData(0x34); // 取得 Y 軸 低位元資料
    Y1 = getData(0x35); // 取得 Y 軸 高位元資料
    Y = ((Y1 << 8)  + Y0) / 256.0;
    Z0 = getData(0x36); // 取得 Z 軸 低位元資料
    Z1 = getData(0x37); // 取得 Y 軸 高位元資料
    Z = ((Z1 << 8)  + Z0) / 256.0;
    sensorRead=analogRead(A2);
    newdata = map(sensorRead, 0, 1023, 0,255);
    Serial.print(newdata);
    Serial.print("\t");
    Serial.print(X);
    Serial.print("\t");
    Serial.print(Y);
    Serial.print("\t");
    Serial.println(Z);
    delay(2000);
  EthernetClient client = server.available();
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
         if (readString.length() < 100) {
          readString += c;
        //check if HTTP request has ended
        if (c == '\n') {
          //check get atring received
          Serial.println(readString);
          //output HTML data header
          client.println("HTTP/1.1 200 OK");
          client.println("Content-Type: text/html");
          client.println();
          //generate data page
          if(readString.indexOf("data") >0) {  //checks for "data" page
            x=x+1; //page upload counter
            client.print("<HTML><HEAD>");
            //meta-refresh page every 1 seconds if "datastart" page
            if(readString.indexOf("datastart") >0) client.print("<meta http-equiv='refresh' content='1'>");
            //meta-refresh 0 for fast data
            if(readString.indexOf("datafast") >0) client.print("<meta http-equiv='refresh' content='0'>");
            client.print("<title>Zoomkat's meta-refresh test</title></head><BODY><br>");
            client.print("page refresh number: ");
            client.print(x); //current refresh count
            client.print("<br><br>");
              //output the value of each analog input pin
            client.print("analog input0 is: ");
            client.print(analogRead(analogInPin0));
            client.print("<br>analog input1 is: ");
            client.print(analogRead(analogInPin1));
            client.print("<br>analog input2 is: ");
            client.print(analogRead(analogInPin2));
            client.print("<br>analog input3 is: ");
            client.print(analogRead(analogInPin3));
            client.print("<br>analog input4 is: ");
            client.print(analogRead(analogInPin4));
            client.print("<br>analog input5 is: ");
            client.print(analogRead(analogInPin5));
            client.println("<br></BODY></HTML>");
          //generate main page with iframe
            client.print("<HTML><HEAD><TITLE>Zoomkat's frame refresh test</TITLE></HEAD>");
            client.print("Zoomkat's Arduino frame meta refresh test 5/25/13");
            client.print("<BR><BR>Arduino analog input data frame:<BR>");
            client.print("&nbsp;&nbsp;<a href='‭http://192.168.1.102:84/datastart' target='DataBox' title=''yy'‬'>META-REFRESH</a>");
            client.print("&nbsp;&nbsp;&nbsp;&nbsp;<a href='‭http://192.168.1.102:84/data' target='DataBox' title=''xx'‬'>SINGLE-STOP</a>");
            client.print("&nbsp;&nbsp;&nbsp;&nbsp;<a href='‭http://192.168.1.102:84/datafast' target='DataBox' title=''zz'‬'>FAST-DATA</a><BR>");
            client.print("<iframe src='‭http://192.168.1.102:84/data' width='350' height='250' name='DataBox‬'>");
            client.print("</iframe><BR></HTML>");
          delay(1);
          //stopping client
          client.stop();
          //clearing string for next read
          readString="";
是哪裡出問題了?
發表於 2018-9-17 18:05:33 | 只看該作者
I2C_Address 沒定義
GMT+8, 2026-8-3 18:39 , Processed in 1.039088 second(s), 7 queries , Apc On.
