查看: 4010|回復: 1
arduino GPS問題請教
發表於 2018-12-28 13:02:27 來自手機 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
想請問一下各位大大,能不能幫小弟解釋一下這個GPS的程式碼
#include<SoftwareSerial.h>
SoftwareSerial GPSModule(10, 11); // TX, RX
int updates;
int failedUpdates;
int pos;
int stringplace = 0;
String timeUp;
String nmea[15];
String labels[12] {"Time: ", "Status: ", "Latitude: ", "Hemisphere: ", "Longitude: ", "Hemisphere: ", "Speed: ", "Track Angle: ", "Date: "};
Serial.begin(57600);
GPSModule.begin(9600);
Serial.flush();
GPSModule.flush();
while (GPSModule.available() > 0)
GPSModule.read();
if (GPSModule.find("$GPRMC,")) {
String tempMsg = GPSModule.readStringUntil('\n');
for (int i = 0; i < tempMsg.length(); i++) {
if (tempMsg.substring(i, i + 1) == ",") {
nmea[pos] = tempMsg.substring(stringplace, i);
stringplace = i + 1;
pos++;
if (i == tempMsg.length() - 1) {
updates++;
nmea[2] = ConvertLat();
nmea[4] = ConvertLng();
for (int i = 0; i < 9; i++) {
Serial.print(labels[i]);
Serial.print(nmea[i]);
Serial.println("");
else {
failedUpdates++;
stringplace = 0;
pos = 0;
String ConvertLat() {
String posneg = "";
if (nmea[3] == "S") {
posneg = "-";
String latfirst;
float latsecond;
for (int i = 0; i < nmea[2].length(); i++) {
if (nmea[2].substring(i, i + 1) == ".") {
latfirst = nmea[2].substring(0, i - 2);
latsecond = nmea[2].substring(i - 2).toFloat();
latsecond = latsecond / 60;
String CalcLat = "";
char charVal[9];
dtostrf(latsecond, 4, 6, charVal);
for (int i = 0; i < sizeof(charVal); i++)
CalcLat += charVal[i];
latfirst += CalcLat.substring(1);
latfirst = posneg += latfirst;
return latfirst;
String ConvertLng() {
String posneg = "";
if (nmea[5] == "W") {
posneg = "-";
String lngfirst;
float lngsecond;
for (int i = 0; i < nmea[4].length(); i++) {
if (nmea[4].substring(i, i + 1) == ".") {
lngfirst = nmea[4].substring(0, i - 2);
//Serial.println(lngfirst);
lngsecond = nmea[4].substring(i - 2).toFloat();
//Serial.println(lngsecond);
lngsecond = lngsecond / 60;
String CalcLng = "";
char charVal[9];
dtostrf(lngsecond, 4, 6, charVal);
CalcLng += charVal[i];
lngfirst += CalcLng.substring(1);
lngfirst = posneg += lngfirst;
return lngfirst;
發表於 2018-12-28 13:05:32 | 只看該作者
讀取 GPS 的資料並顯示出來
GMT+8, 2026-10-3 11:07 , Processed in 0.170459 second(s), 7 queries , Apc On.
