查看: 5082|回復: 0
AT89C2051驅動步進馬達與原碼
發表於 2006-8-6 15:43:48 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
AT89C2051驅動步進馬達與原碼
程序
stepper.c
stepper.hex
* STEPPER.C
* sweeping stepper's rotor cw and cww 400 steps
* Copyright (c) 1999 by W.Sirichote
#include c:\mc51\8051io.h /* include i/o header file */
#include c:\mc51\8051reg.h
register unsigned char j,flag1,temp;
register unsigned int cw_n,ccw_n;
unsigned char step[8]={0x80,0xc0,0x40,0x60,0x20,0x30,0x10,0x90}
#define n 400
/* flag1 mask byte
0x01 run cw()
0x02 run ccw()
main()
flag1=0;
serinit(9600);
disable(); /* no need timer interrupt */
cw_n = n; /* initial step number for cw */
flag1 |=0x01; /* initial enable cw() */
while(1){
tick_wait(); /* wait for 10ms elapsed */
energize(); /* round-robin execution the following tasks every 10ms */
cw();
ccw();
cw(){
if((flag1&0x01)!=0)
cw_n--; /* decrement cw step number */
if (cw_n !=0)
j++; /* if not zero increment index j */
{flag1&=~0x01; /* disable cw() execution */
ccw_n = n; /* reload step number to ccw counter */
flag1 |=0x02; /* enable cww() execution */
ccw(){
if((flag1&0x02)!=0)
ccw_n--; /* decremnent ccw step number */
if (ccw_n !=0)
j--; /* if not zero decrement index j */
{flag1&=~0x02; /* disable ccw() execution */
cw_n = n; /* reload step number to cw counter */
flag1 |=0x01; /* enable cw() execution */
tick_wait(){ /* cputick was replaced by simpler ASM code 10ms wait */
asm" JNB TCON.5,*"; /* wait for TF0 set */
asm" CLR TCON.5"; /* clear TF0 for further set */
asm" ORL TH0,#$DC"; /* reload TH0 with $DC, TL0 = 0 */
energize(){
P1 = step[(j&0x07)]; /* only step 0-7 needed */
http://www.52dianzi.com/document/70.htm
GMT+8, 2026-10-3 08:38 , Processed in 0.546047 second(s), 9 queries , Apc On.
