查看: 6399|回復: 6
GWS S03N-II HP and GWS S03N-II D HP2BB
發表於 2010-11-20 10:07:48 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
GWS new servos S03N-II HP and GWS S03N-II D HP2BB will be avalible soon.
這是規格超越日本 F 牌暢銷世界的 S9252 (售價為 NT$2000+ ) 規格的GWS產品! GWS S03N2價格卻只需要 NT$300~510.
由廣營電子在中國研發製造的舵機瞬時性能超越日本韓國與德國的水平!  很高興在此與您分享我們的成果!
我們不斷的刷新紀錄 創造世界性的新指標與規格.
GWS S03N-II HP MSRP$10.00 for 4.8~6.0v ( 台灣售價 NT$300 )
4.8v 8kg 0.148sec.. 6.0v 9kg 0.130sec.
GWS S03N-II D HP2BB MSRP$17.00 4.8~6.0~7.4~8.4v ( 台灣售價 NT$510 )
4.8v 8.2kg 0.134sec.. 6.0v 9kg 0.114sec.
7.4v 10.5kg 0.102sec.. 8.4v 11.4kg 0.095sec.
As usual, GWS always more gear ratios for your choice of application to get the best optimization!
GWS new servos S03N-IIF HP and GWS S03N-IIF D HP2BB will be avalible soon. Yet, there another speedy choice GWS S03N-IIXF HP and GWS S03N-IIXF D HP2BB. ( F=Fast, XF=Xtra Fast D=Digital ).
GWS S03N-IIF HP MSRP$10.00 for 4.8~6.0v
4.8v 7.0kg 0.131sec.. 6.0v 8.0kg 0.123sec.
GWS S03N-IIF D HP2BB MSRP$17.00 4.8~6.0~7.4~8.4v
4.8v 7.0kg 0.110sec.. 6.0v 8.1kg 0.098sec.
7.4v 9.1kg 0.081sec.. 8.4v 9.8kg 0.074sec.
GWS S03N-IIXF HP MSRP$10.00 for 4.8~6.0v
4.8v 6.0kg 0.099sec.. 6.0v 6.8kg 0.086sec.
GWS S03N-IIXF D HP2BB MSRP$17.00 4.8~6.0~7.4~8.4v
4.8v 6.0kg 0.089sec.. 6.0v 7.0kg 0.078sec.
7.4v 8.0kg 0.070sec.. 8.4v 8.5kg 0.064sec.
All of those servos weight only 33g.
You may easily compared with a F brand most popular S9252 servo specs as below: Price:$84.99
But GWS analog only $10.00, Digital type only $17.00. While both versions performance result better than S9252.
Control System: +Pulse Width Control 1520usec Neutral
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 4.8 Volts Only
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (4.8V): 0.14sec/60 degrees at no load
Stall Torque (4.8V): 92 oz/in. (5.5kg.cm)
Operating Angle: 45 Deg. one side pulse traveling 400usec
360 Modifiable: Yes
Direction: Counter Clockwise/Pulse Traveling 1520-1900usec
Motor Type: Coreless Motor
Potentiometer Drive: Indirect Drive
Bearing Type: Dual Ball Bearing
Gear Type: All Nylon Gears
Connector Wire Length: 12"
Dimensions: 1.6" x 0.8"x 1.5" (41 x 20 x 38mm)
Weight: 1.8oz. (50g)
Who give more torque? Who run faster? Yet, GWS S03N2 is way much lighter!
Just measured and got 33g ( 1.16oz ) only! By far better than S9252's 50g weight.
2010年十一月底上限 相信十二月中旬前 你可以在台灣各大專業經銷商買到!
敬請拭目以待!
 樓主| 發表於 2010-11-20 10:33:07 | 只看該作者
I hadrly to believe such a nice servo specs will not be popular in RC indusrty.
GWS 哪裡做得還不夠完善之處 也請時時叮嚀我們!
這樣具有優勢的產品如果沒有大量暢銷 我們業務部固然該要自我反省! 經銷商也該要自我反省!
崇洋媚外? 貪圖便宜?
來到大陸設廠 六年來認識了許多新朋友與工作夥伴! 但願中國要勇敢的站起來! 需要妳們一起努力!
最近要首批上線 歡迎預約 或者 請經銷商代訂
價格和原有 S03N 或是 S03T 相同 性能大躍進 價格不提升!
發表於 2010-11-20 13:28:36 | 只看該作者
本帖最後由 lakers3411 於 2010-11-20 16:06 編輯
真的可以說不完善的地方嗎~
我有好多想說
唯一敢馬上說的就是,貴公司的人態度真的不是很好,定個東西好幾家模型店就沒有
貴公司又一直叫我去模型店買@@
還有阿價個也不是真的第一考量,如果花500可是一個月壞4顆,跟花2000用了1年
那我還是要花2000
發表於 2010-11-20 23:57:23 | 只看該作者
其實...
目前我觀察到機器人應用領域的需求有兩個極端
一個是拚命貪圖便宜, 眼中只有大陸貨<---多數人屬於這種, 我也是^__^a
一個是拚命追求品質, 一定要耐操穩定速度快, 價格不是很關心
EX: Laker 這種天天和機器人在一起的人, 恐怕連睡覺都抱著睡XDD
EX: 我幫科學園區開發特殊功能機械手臂, SERVO所有機構零件都鈦合金作的
周圍會買GWS 馬達的人主要有兩種
初學---結果去模型店只買到GWS的(我家附近的模型店全部只賣GWS, 雷虎的都賣一個三千以上)
看書---看市面上高職之類的課本, 因為裡面推薦GWS , 所以之後就一直這樣買了
廣營的主力主要都在塑膠齒
主因客戶是遙控領域
尤其是飛機, 因這領域要求很輕巧, 金屬齒完全不適合
就像我幫人作非機, 也只用塑膠齒, 反正玩飛機的人錢太多, 甚至接受玩個幾次就換馬達的人還不少
這並不是壞事, 畢竟各領域都有提供會比較完整
塑膠齒在於輕 ,但耐操度就不如金屬的, 板上很多人都是機器魔人, 對於耐操度的要求相對嚴格
也許該加強這方面的產品才是
建議GWSCEO仔細調查機器人領域的需求, 我想, 推出適合這領域的規格對GWS來說不會困難
畢竟您公司作出來的S03N系列
8V能有11kg/0.1秒左右的表現, 這種SERVO若改金屬齒一顆都要價好幾千的
但我也同時想到一個問題, 這樣的表現, 塑膠齒輪是否同時代表壞的很快??
是否考慮受力大的幾個齒輪換成金屬的
公司是否有相關的耐操度測試可以參考
還請幫忙解惑
發表於 2010-11-21 07:31:45 | 只看該作者
本帖最後由 lakers3411 於 2010-11-21 07:38 編輯
其實是不是全金屬齒,我不是太在意,就像我常說的如果只壞齒輪真的比用金屬齒卡到就整個燒掉好很多
我想要的耐操是電路方面,也許可以用再好一點的規個(小弟對伺服機壞的定義不再於一直崩齒,在於整顆燒掉)
這樣也許比較不會一下就燒,還有訊號要夠穩定,不然一直抖@@
齒輪朔膠壞了可以換一包了不起100,而且你就可以發現哪些地方一直崩齒,
也就表示你在設計動作或設計時這地方要改善
(相對的你在這些地方用金屬齒的話不能治本只能治標,最慘的是燒了整個板子也跟著燒)
在碰過這麼多伺服機的經驗之下,買便宜的只有一開始很爽
後面就很想哭,沒事就給你燒掉,慘的事還燒到控制板@@
不然就是再重要場合給你燒掉.....這樣一且都泡湯,
畢竟看的人不會說是馬達太爛,他們只會說是設計的人不好
(一直壞掉,這樣加一加,真的事直接買好一點的,安心又不用一直換,拆開換伺服機很累ㄟ~)
所以我現再都還是會選好一點的,一年都正常操作可能都不用換
我有一台用日本伺服機的2年了只壞過一顆(崩齒而已,換個齒輪就好)
所以還是得看個人勒,看是要貪圖一時的便宜,還是要一次搞定
 樓主| 發表於 2010-11-22 08:10:57 | 只看該作者
廣營的主力不只是 "廣營的主力主要都在塑膠齒"
二十年前 GWS 我們率先採用瑞士滾齒機加工製程製作全金屬齒機種 但是沒有被玩家"認真的發現"!
後來 F 牌只好跟進喔!
 樓主| 發表於 2010-11-22 08:19:47 | 只看該作者
本帖最後由 gws4ceo 於 2010-11-22 08:26 編輯
真的可以說不完善的地方嗎~
我有好多想說
唯一敢馬上說的就是,貴公司的人態度真的不是很好,定個東西好幾 ...
lakers3411 發表於 2010-11-20 13:28
通常我們會建議玩家支持就近的模型專業經銷商!
但是如果經銷商不肯支持提供您即時的服務? 您可以告知廣營的客服業務人員具體事由經過
我們也能提供您全面性的服務!
http://www.rcgroups.com/forums/showthread.php?t=692955The "Lonely Birds" will provide GWS products to anyone GWS flyer arround the world!
GWS will planning to to work on a new programe similar to Early Birds.
The "Lonely Birds" will provide GWS products to anyone GWS flyer arround the world under the following conditions:
1. There did not have an importer in your country sell GWS.
2. The importer do not carry the exactly items of GWS products you need.
3. The importer out of stock for a long time for such items, yet did not booking to GWS so far.
Wish this will make every one happy to get GWS products on time in any conners of the world!
The detail, pls contect GWS service@gws.com.tw
Will be post on GWS web soon.
GMT+8, 2026-10-3 16:12 , Processed in 0.197938 second(s), 8 queries , Apc On.
