查看: 5063|回復: 0
GWS S03Q2 standard size Quick speedy servo
發表於 2011-7-30 17:44:00 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
GWS S03Q2 tested result:
S03Q2+ S D
4.8V 0.072sec 5.6Kg-cm
6.0V 0.063sec 6.6Kg-cm
7.4V 0.052sec 7.9Kg-cm
8.4V 0.048sec 8.2Kg-cm
S03Q2+ D
4.8V 0.065sec 4.3Kg-cm
6.0V 0.056sec 4.9Kg-cm
7.4V 0.046sec 5.7Kg-cm
8.4V 0.043sec 6.0Kg-cm
S03Q2+ F D
4.8V 0.060sec 3.3Kg-cm
6.0V 0.053sec 3.7Kg-cm
7.4V 0.043sec 4.3Kg-cm
8.4V 0.039sec 4.6Kg-cm
S03Q2+ XF D
4.8V 0.051sec 2.2Kg-cm
6.0V 0.043sec 2.6Kg-cm
7.4V 0.038sec 3.0Kg-cm
8.4V 0.036sec 3.2Kg-cm
Since the rotation speed are too fast in this series servos, equipped with 2BB is a MUST. However, the out put torque is relative less than the other brothers, so we use POM gears for keep the weight lighten!
The 2BB digital version will go for $17.00/ea only.
The 2BB linear version will go for $12.00/ea only. But the speed will slower some, and less 5~10% torque.
No matter how, GWS S03Q2 Quick speedy servo will be the fastest servo among all the standard size servo at this price tag.
How do you like?
GMT+8, 2026-7-1 11:59 , Processed in 0.303741 second(s), 7 queries , Apc On.
