查看: 4135|回復: 1
偵錯問題
發表於 2012-3-5 19:59:49 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <LiquidCrystal.h>
int sensorValue1 = 0;
int sensorValue2 = 0;
LiquidCrystal lcd(3, 4, 5, 8, 9, 10, 11); //初始化LCD
sensorValue1 = analogRead(0);
sensorValue2 = analogRead(1);
Serial.print("Value = " );
Serial.println(sensorValue1,sensorValue2);
lcd.begin(16, 2); //設定LCD大小
lcd.setCursor(0,0);
lcd.print(sensorValue1); //輸出字串
lcd.setCursor(0,1)
lcd.print(sensorValue2);
delay(100);
顯示這樣的錯誤是什麼意思
sketch_mar05a.cpp: In function 'void loop()':
sketch_mar05a:19: error: expected `;' before 'lcd'
發表於 2012-3-6 00:02:48 | 只看該作者
lcd.setCursor(0,1)
後面要加分號
分號是C語言規定的指令結束
GMT+8, 2026-10-3 13:34 , Processed in 0.177348 second(s), 8 queries , Apc On.
