查看: 4513|回復: 0
RFID結合XBEE的程式碼
發表於 2012-3-19 00:55:52 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最後由 z159357z2000 於 2012-3-19 14:34 編輯
我正在做一個專題
是想要用RFID收到TAG的訊息用XBEE傳給出來
我是要把BUTTON變成RFID
請問程式是要怎麼合併了?
這是我的程式碼
XBEE:
const intbuttonPin = 12;
按鍵引腳數量
const int ledPin=
13;
// LED
引腳數量
// variableswill change:
int buttonState= 0;
變量讀取按鍵狀態
longpreviousMillis = 0;
將存儲LED被更新的最後一次
// the followvariables is a long because the time, measured in miliseconds,
// will quicklybecome a bigger number than can be stored in an int.
long interval =1000;
// interval at which toblink (milliseconds)
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
void loop(){
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState == HIGH) {
// turn LED on:
digitalWrite(ledPin, HIGH);
Serial.println("apple");
delay(300);
// so won't send msg too many times
else {
// turn LED off:
digitalWrite(ledPin, LOW);
// Simply to keep xbee alive
unsigned long currentMillis = millis();
if(currentMillis - previousMillis >interval) {
// save the last time you blinked the LED
previousMillis = currentMillis;
Serial.println("sync");
RFID:
int val =0;
char code[10];
int bytesread =0;
Serial.begin(2400);// 將Serial RX pin(digital 0) 設為2400bps
pinMode(2,OUTPUT);// 將digital pin 2設為輸出,以便傳送訊號給RFID reader
voidloop() {
digitalWrite(0,LOW);                 //
啟動RFID reader
if(Serial.available()> 0) {          //
假如reader有資料讀入
   if((val = Serial.read()) == 10) {   //
檢查標頭是否為10
     bytesread = 0;
     while(bytesread<10){
       if( Serial.available() > 0) {
         val = Serial.read();
         if((val == 10)||(val == 13)) { //假如讀到表示標頭的10或結束的13
           break;                      //
停止讀取
         code[bytesread] = val;         //紀錄讀入的值
         bytesread++;                  //準備讀取下一個位元
     if(bytesread == 10){             //
如果十個號碼皆讀取成功
       Serial.print("TAG code is: ");
       Serial.println(code);           //
顯示TAG號碼
     bytesread = 0;
     digitalWrite(0,HIGH);            //
關閉RFID reader
     delay(500);
GMT+8, 2026-10-3 09:45 , Processed in 0.273102 second(s), 8 queries , Apc On.
