查看: 5121|回復: 1
超音波 sos
發表於 2012-3-30 10:39:22 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
unsigned char analogPin = 0;
float val = 0;
int pwm_a = 3;
int pwm_b = 11;
int dir_a = 12;
int dir_b = 13;
pinMode(pwm_a, OUTPUT);
pinMode(pwm_b, OUTPUT);
pinMode(dir_a, OUTPUT);
pinMode(dir_b, OUTPUT);
  val = analogRead(analogPin)*1.38;    // read the value from the
  Serial.print("EZ1 distance = ");
  Serial.print(val);
  Serial.println(" cm");
  delay(100);
digitalWrite(dir_a, HIGH);
digitalWrite(dir_b, HIGH);
delay(100);
analogWrite(pwm_a,250);
analogWrite(pwm_b,250);
delay(100);
if (val < 100) // obstacle detected
//Stop both motors...
analogWrite(pwm_a, 100);
analogWrite(pwm_b, 100);
delay(1000); // ...and pause for a second
else if  ( val < 50 );
digitalWrite(dir_a, LOW);
analogWrite(pwm_a, 150);
analogWrite(pwm_b, 50);
delay (1000);
無法照程式計畫走
請問大大
哪裡有問題
一開始的動作變成原地自轉..
發表於 2012-4-5 21:52:13 | 只看該作者
原來計畫怎麼走?
有確認過車子可以直線前進嗎?
GMT+8, 2026-10-3 13:42 , Processed in 0.184408 second(s), 8 queries , Apc On.
