查看: 4878|回復: 1
arduino不能控制motor
發表於 2012-12-26 16:16:50 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
arduino不能控制motor
當接駁了AA電池在pin 12和GND,它會自動不停轉動,但是我沒有使用bluetooth控制。
但當我使用bluetooth控制pin12時,motor轉聲加大了。
以下是Arduino Board Programming
  MOBOT BTCar
  Author: Daniel Garrote
  Project: MOBOT
  Project URL: www.mobot.es
int forward = 12;     // Pin 12 - Forward
int reverse = 11;    // Pin 11 - Reverse
int left = 10;        // Pin 10 - Left
int right = 9;        // Pin 9  - Right
int turbo = 8;        // Pin 8  - Turbo
int short_lights = 7;    // Pin 7  - Short Lights
int long_lights = 6;    // Pin 6  - Long Lights
int back_lights = 5;    // Pin 5  - Back Lights
int reverse_lights = 4;    // Pin 4  - Reverse Lights
char val;  // Variable to receive data from the serial port
  // initialize the digital pins as output
  pinMode(forward, OUTPUT);
  pinMode(reverse, OUTPUT);
  pinMode(left, OUTPUT);
  pinMode(right, OUTPUT);
  pinMode(turbo, OUTPUT);
  pinMode(short_lights, OUTPUT);
  pinMode(long_lights, OUTPUT);
  pinMode(back_lights, OUTPUT);
  pinMode(reverse_lights, OUTPUT);
  Serial.begin(9600);     // Start serial communication at 9600bps
// Fordward action
void go_forward() {
  digitalWrite(forward, HIGH);
  digitalWrite(turbo, LOW);
  digitalWrite(reverse, LOW);
// Stop Forward action
void stop_go_forward() {
  digitalWrite(forward, LOW);
// Reverse action
void go_reverse() {
  digitalWrite(reverse, HIGH);
  digitalWrite(reverse_lights, HIGH);
// Stop Reverse action
void stop_go_reverse() {
  digitalWrite(reverse_lights, LOW);
// Turbo action
void go_turbo() {
  digitalWrite(turbo, HIGH);
// Stop Turbo action
void stop_go_turbo() {
// Left action
void go_left() {
  digitalWrite(left, HIGH);
  digitalWrite(right, LOW);
// Right action
void go_right() {
  digitalWrite(right, HIGH);
  digitalWrite(left, LOW);
// Stop turn action
void stop_turn() {
// Stop car
void stop_car() {
// Short Lights ON
void lights_on() {
  digitalWrite(short_lights, HIGH);
  digitalWrite(back_lights, HIGH);
// Short Lights OFF
void lights_off() {
  digitalWrite(short_lights, LOW);
  digitalWrite(back_lights, LOW);
// Long Lights ON
void long_lights_on() {
  digitalWrite(long_lights, HIGH);
// Long Lights OFF
void long_lights_off() {
  digitalWrite(long_lights, LOW);
// Reverse Lights ON
void back_lights_on() {
// Reverse Lights OFF
void back_lights_off() {
// Read serial port and perform command
void performCommand() {
  if (Serial.available()) {
    val = Serial.read();
    if (val == 'f') { // Forward
      go_forward();
    } else if (val == 'z') { // Stop Forward
      stop_go_forward();
    } else if (val == 'b') { // Backward
      go_reverse();
    } else if (val == 'y') { // Stop Backward
      stop_go_reverse();
    } else if (val == 't') { // Turbo
      go_turbo();
    } else if (val == 'x') { // Stop Turbo
      stop_go_turbo();
    } else if (val == 'l') { // Right
      go_right();
    } else if (val == 'r') { // Left
      go_left();
    } else if (val == 'v') { // Stop Turn
      stop_turn();
    } else if (val == 's') { // Stop
      stop_car();
    } else if (val == 'a') { // Short Lights
      lights_on();
    } else if (val == 'c') { // Stop Short Lights
      lights_off();
    } else if (val == 'd') { // Long Lights
      long_lights_on();
    } else if (val == 'e') { // Stop Long Lights
      long_lights_off();
  performCommand();
發表於 2012-12-30 23:15:53 | 只看該作者
你接線似乎有點問題,
請參考 >> http://www.me.umn.edu/courses/me ... witchled/index.html
或google一下正確的接線方式.
GMT+8, 2026-10-3 04:49 , Processed in 0.139179 second(s), 8 queries , Apc On.
