查看: 3461|回復: 0
arduino 板子壞掉問題?
發表於 2013-7-5 10:23:27 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
請問我的程式碼都一樣#include <Stepper.h>
//int incomingByte = 0;
const int stepsPerRevolution = 200;
Stepper myStepper(stepsPerRevolution, 2, 3, 4, 5);
char val;
int pos=0;
int x;
  // myStepper.setSpeed(60);
  Serial.begin(9600); //Start serial connection, 9600 baud
  if(Serial.available() > 0){
    Serial.println("Serial.available");
    Serial.println(val);
    val = Serial.read();
  if( val == '1' ) //if diference is greater than 2 steps.
    Serial.println("turn right");
    myStepper.step(1);      // move one step to the left.
    delay(50);
    //pos++;
    Serial.println(x);
  else if( val == '0')
    Serial.println("turn left");
    myStepper.step(-1);       // move one step to the right.
    delay(50);
    //pos--;
    Serial.println(x);
  else if( val == '2')
    Serial.println("stop");
    myStepper.step(0);       // move one step to stop
    delay(50);
    //pos--;
    Serial.println(x);
  //  Serial.println(pos);      //for debuging...
  //  Serial.println(val);
  //  delay(100);
原本輸入0或是1會正反轉  現在變成輸入0或是1會左右一直極小幅度的轉
請問是不是因為上次接電源供應器結果顯示短路的原因呢..我的版子是LEONARDO
上次也發生過這樣的問題 結果是換一塊版子才成功 (也是用一樣的程式碼)
GMT+8, 2026-10-3 04:51 , Processed in 0.134545 second(s), 8 queries , Apc On.
