查看: 4400|回復: 1
VB.NET去控制RFID卡的問題?
發表於 2013-7-9 10:40:36 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最後由 k940714675 於 2013-7-9 20:26 編輯
我是剛觸碰Arduino跟VB的新手,想問各位高手們知道如何用VB.NET去讀取Arduino板的RFID卡的資料,我完全沒什麼頭緒要怎麼打,還請各位前輩指點!
Arduino 的部分我參考了標機器人的程式碼!
而VB的部分我完全沒頭緒,請各位前輩指點!
Arduino的程式碼:
#include <SoftwareSerial.h>
#define RFID_WRITE 0x02
#define RFID_READ 0x01
#define txPin 6
#define rxPin 8
SoftwareSerial mySerial(rxPin, txPin);
int val;
int runs = 0;
Serial.println("RFID Read/Write Test");
mySerial.begin(9600);
pinMode(txPin, OUTPUT);
pinMode(rxPin, INPUT);
void suppressAll()
if(mySerial.available() > 0)
{ mySerial.read();
suppressAll();
void loop(){ int val;
mySerial.print("!RW");
mySerial.write(byte(RFID_READ));
  mySerial.write(byte(32));
val = mySerial.read();
if (val != 1)
{suppressAll();}
Serial.print(val, HEX);
delay(750);
 樓主| 發表於 2013-7-9 15:24:17 | 只看該作者
vb的程式碼只知道:
Imports System.IO
Imports System.IO.Ports
Imports System.Threading
Public Class Form1
    Shared _serialport As SerialPort
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        SerialPort1.Close()
        SerialPort1.PortName = "com3"
        SerialPort1.BaudRate = 9600
        SerialPort1.DataBits = 8
        SerialPort1.Parity = Parity.None
        SerialPort1.StopBits = StopBits.One
        SerialPort1.Handshake = Handshake.None
        SerialPort1.Encoding = System.Text.Encoding.Default
    End Sub
    Private Sub Label1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Label1.Click
    End Sub
End Class
GMT+8, 2026-10-3 04:51 , Processed in 0.146794 second(s), 8 queries , Apc On.
