查看: 3646|回復: 2
求救 兩組程式碼做結合~
發表於 2013-11-15 18:04:19 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最後由 man3838 於 2013-11-15 18:16 編輯
兩組程式碼結合後
紅外線卻失效了 求解
紅外線感應器PIR
const int PIRSensor = 2; // 紅外線動作感測器連接的腳位
const int ledPin = 13; // LED 腳位
int sensorValue = 0; // 紅外線動作感測器訊號變數
int val = 0;
Serial.begin(4800); //設定終端機的Port位
pinMode(PIRSensor, INPUT);
pinMode(ledPin, OUTPUT);
void loop(){
sensorValue = digitalRead(PIRSensor);
if (sensorValue == HIGH) {
digitalWrite(ledPin, HIGH); // 有人,開燈
val = digitalRead(13);
Serial.println("1234");
else {
digitalWrite(ledPin, LOW); // 沒人,關燈
結合後
#include <WiShield.h>
#define WIRELESS_MODE_INFRA   1
#define WIRELESS_MODE_ADHOC   2
unsigned char local_ip[]       = {192,168,0,101};
unsigned char gateway_ip[]     = {192,168,0,1};
unsigned char subnet_mask[]    = {255,255,255,0};
char ssid[] = {"dlink"};
unsigned char security_type    = 0;
const prog_char security_passphrase[] PROGMEM = {"abcde"};
prog_uchar wep_keys[] PROGMEM = {
   0x41, 0x42, 0x43, 0x44, 0x45, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
unsigned char wireless_mode = WIRELESS_MODE_INFRA;
unsigned char ssid_len;
unsigned char security_passphrase_len;
char recvChar;
char sms[8];
char message[32];
const int Motor_M1 = 7;
struct NetworkPackage
   int dataLength;
   char data[32];
NetworkPackage  mNetworkPack;
   recvChar = NULL;
   WiFi.init();
  pinMode(Motor_M1, OUTPUT);
   if(NULL != recvChar) {
      if(!strcmp(mNetworkPack.data, "bulbon"))
        bulbon(0,0);
      if(!strcmp(mNetworkPack.data, "bulboff"))
        bulboff(0,0);
        if(!strcmp(mNetworkPack.data, "fanon"))
        fanon(0,0);
      if(!strcmp(mNetworkPack.data, "fanoff"))
        fanoff(0,0);
      recvChar = NULL;
   WiFi.run();
else {
void bulbon(byte flag, byte numOfValues)
  Serial.println("bulbon : ");
  digitalWrite( Motor_M1, HIGH);
void bulboff(byte flag, byte numOfValues)
  Serial.println("bulboff : ");
  digitalWrite( Motor_M1, LOW);
void fanon(byte flag, byte numOfValues)
  Serial.println("fanon : ");
void fanoff(byte flag, byte numOfValues)
  Serial.println("fanoff : ");
兩組程式碼結合後
紅外線卻失效了 求解
 樓主| 發表於 2013-11-15 18:17:48 | 只看該作者
遙控開關
char recvChar;
char sms[8];
char message[32];
   int dataLength;
   char data[32];
   recvChar = NULL;
   WiFi.init();
        bulbon(0,0);
        bulboff(0,0);
        fanon(0,0);
        fanoff(0,0);
      recvChar = NULL;
   WiFi.run();
發表於 2013-11-19 05:07:31 | 只看該作者
可能是執行WiFi來不及執行digitalRead(PIRSensor)
你可以試
WiFi.run();
之後 加入delay(50);
若依然無效,請參考:
Arduino PIR eMail Alarm = Arduino + PIR Sensor + WiFi Shield + Google Engine App
http://sinocgtchen.blogspot.tw/2 ... rt-arduino-pir.html
GMT+8, 2026-10-3 05:33 , Processed in 0.333231 second(s), 7 queries , Apc On.
