查看: 3545|回復: 0
Arduino搭配伺服馬達下個指令會突然斷掉
發表於 2013-11-30 18:07:57 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
功能想法:想做一個可以下指令給馬達驅動,是由0度到九十度再由九十度到0度
可是第一次給指令卻可以執行,但再給一次指令卻發生問題,請各位高手可以幫我們求解。
這是我做的驅動馬達程式碼:
#include <Servo.h>
Servo myservo;
myservo.attach(9);
    if(Serial.available())
    char ch = Serial.read(); //CHAR=字元
    switch (ch)
        case 'A':
        myservo.write(0);
        delay(2000);
        digitalWrite(9,HIGH);
        case 'B':
         myservo.write(90);
        delay(2000);
        digitalWrite(9,LOW);
這是會發生以下的問題:
        java.io.IOException:
        Input/output error in writeArray
at gnu.io.RXTXPort.writeArray(Native Method)
at gnu.io.RXTXPort$SerialOutputStream.write(RXTXPort.java:1124)
at processing.app.Serial.write(Serial.java:517)
at processing.app.Serial.write(Serial.java:540)
at processing.app.SerialMonitor.send(SerialMonitor.java:200)
at processing.app.SerialMonitor.access$100(SerialMonitor.java:32)
at processing.app.SerialMonitor$4.actionPerformed(SerialMonitor.java:96)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236)
at java.awt.Component.processMouseEvent(Component.java:6263)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6028)
at java.awt.Container.processEvent(Container.java:2041)
at java.awt.Component.dispatchEventImpl(Component.java:4630)
at java.awt.Container.dispatchEventImpl(Container.java:2099)
at java.awt.Component.dispatchEvent(Component.java:4460)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
at java.awt.Container.dispatchEventImpl(Container.java:2085)
at java.awt.Window.dispatchEventImpl(Window.java:2475)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
GMT+8, 2026-10-3 05:32 , Processed in 0.236831 second(s), 7 queries , Apc On.
