查看: 5852|回復: 2
arduino的Vin pin可以接12v嗎?
發表於 2014-3-27 12:40:53 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最後由 pizg 於 2014-4-26 09:51 編輯
Q: arduino的Vin pin可以接12v嗎?
A: 7~12V的外部電源都可以連接Vin pin, 供電給Arduino使用.
請詳下列文字(摘自 http://arduino.cc/en/Main/ArduinoBoardUno)
Power
The Arduino Uno can be powered via the USB connection or with an external power supply. The power source is selected automatically.
External (non-USB) power can come either from an AC-to-DC adapter (wall-wart) or battery. The adapter can be connected by plugging a 2.1mm center-positive plug into the board's power jack. Leads from a battery can be inserted in the Gnd and Vin pin headers of the POWER connector.
The board can operate on an external supply of 6 to 20 volts. If supplied with less than 7V, however, the 5V pin may supply less than five volts and the board may be unstable. If using more than 12V, the voltage regulator may overheat and damage the board. The recommended range is 7 to 12 volts.
The power pins are as follows:
  • VIN. The input voltage to the Arduino board when it's using an external power source (as opposed to 5 volts from the USB connection or other regulated power source). You can supply voltage through this pin, or, if supplying voltage via the power jack, access it through this pin.
  • 5V.This pin outputs a regulated 5V from the regulator on the board. The board can be supplied with power either from the DC power jack (7 - 12V), the USB connector (5V), or the VIN pin of the board (7-12V). Supplying voltage via the 5V or 3.3V pins bypasses the regulator, and can damage your board. We don't advise it.
  • 3V3. A 3.3 volt supply generated by the on-board regulator. Maximum current draw is 50 mA.
  • GND. Ground pins.
  • IOREF. This pin on the Arduino board provides the voltage reference with which the microcontroller operates. A properly configured shield can read the IOREF pin voltage and select the appropriate power source or enable voltage translators on the outputs for working with the 5V or 3.3V.
發表於 2014-3-31 00:44:58 | 只看該作者
回復 1# pizg
    可以呀! 9V或12V都可以!
發表於 2014-5-4 04:40:35 | 只看該作者
在Nano版上使用過12V 會有點不穩!
GMT+8, 2026-10-3 05:33 , Processed in 0.149475 second(s), 8 queries , Apc On.
