查看: 5906|回復: 5
sell a DIY 3dprinter kit
發表於 2014-7-26 11:29:55 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
I did some 3d printers, simple, strong, cheap.
Not business, I just only need to do the next new machine costs.
 樓主| 發表於 2014-8-15 10:48:38 | 只看該作者
In your DIY accessories price is $0.8!
 樓主| 發表於 2014-8-27 11:29:30 | 只看該作者
Today's activities!!!!!!!!!!!Delta 3 d printers, promotional activities,
group buying the cheapest!Welcome to snap up!
buy:http://www.reprap.cn/he-3d-the-c ... inter-kit-p-85.html
skype:reprap.cn
 樓主| 發表於 2014-9-2 12:24:22 | 只看該作者
 樓主| 發表於 2014-9-3 15:37:21 | 只看該作者
Products Description:
Technical parameters:
1, the printing technology: the accumulation of fused deposition molding (FDM)
3, overall dimensions: height:600 mm  width:320 mm   length:320 mm 4, the total weight: 10 kg (including packaging)
5, external frame: imported aluminum, steel (laser precision cutting)
6, extruder:remotely and  high-speed extrusion machine
7, the print head material: copper, aluminum, polyether ether ketone material forming
8, nozzle diameter: 0.4 mm (18, J - head hotend)
9 nozzle number: single nozzle
10 and the data format: STL
11, software: Repetier host
12, print range: 160 mm diameter     hight  230 mm
13, power input: AC110-220 - v
14, the power supply output: DC 12 v 7 a
15,print plate: high borosilicate glass    180 mm in diameter
16, synchronous belt wheel / 16 teeth, belt GT2
17, equipped with LCD screen
The performance parameters
1, print thickness of 0.05 mm to 4 mm
, 2, mechanical precision is 0.0125mm
3, the operating system, Windows/Mac/Linux
, 4, high-speed USB device interface or SD card
Shipping list:
1, 3 d DLT - 180 delta printer (the kit)
2, the power supply 1 (12 v 7 a)
3,USB cable 1
4 blue import 3 m adhesive tape (mesa print use, prevent deformation)
5, He3D material frame 1
6, print the test material to 100 grams
 樓主| 發表於 2014-9-6 13:01:25 | 只看該作者
GMT+8, 2026-10-3 05:15 , Processed in 0.153834 second(s), 8 queries , Apc On.
