查看: 4193|回復: 0
DLT -180 Delta 3d printer Open source 3 d printers The complete
發表於 2014-7-30 15:15:58 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
Technical parameters:
1, the printing technology: the accumulation of fused deposition molding (FDM)
3, overall dimensions: height:600 mm width:320 mm length:320 mm 4, the total weight : 10 kg (including packaging)
5, external frame: imported aluminum, steel (laser precision cutting)
6, extruder:remotely and high-speed extrusion machine
7, the print head material: copper, aluminum, polyether ether ketone material forming
8, nozzle diameter: 0.4 mm (18, J - head hotend)
9 nozzle number: single nozzle
10 and the data format: STL
11, software: Repetier host
12, print range: 160 mm diameter hight 230 mm
13, power input: AC110- 220 - v
14, the power supply output: DC 12 v 7 a
15,print plate: high borosilicate glass 180 mm in diameter
16, synchronous belt wheel / 16 teeth, belt GT2
17, equipped with LCD screen The performance parameters 1, print thickness of 0.05 mm to 4 mm , 2, mechanical precision is 0.0125mm 3, the operating system, Windows/Mac/Linux , 4, high-speed USB device interface or SD card Shipping list: 1, 3 d DLT - 180 delta printer (fully assembled) 2, the power supply 1 (12 v 7 a) 3,USB cable 1 4 blue import 3 m adhesive tape (mesa print use, prevent deformation) 5, He3D material frame 1 6, print the test material to 100 grams
GMT+8, 2026-10-3 02:58 , Processed in 0.110582 second(s), 8 queries , Apc On.
