查看: 3690|回復: 0
There is a little thing is very popular
發表於 2014-8-8 13:39:25 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
He3D-B140 3D Printer Completed assembly Huxley Reprap
Printing is the most widespread: 140 x140x110mm
  nozzle diameter:0.4mm(if you want 0.5mm,please left message for us)
Dimension: 260 x280x280mm
     Printing material: ABS, PLA, diameter of 1.75 mm.
     Main: melzi
     Power supply: input AC110V - 220v, output: DC24V
     Heating bed building surface: PCB, aluminum countertops, to reduce
           the complexity of assembly, to ensure that the parts without deformation.
     Accuracy standards: 0.1 mm
     Resolution: 0.0125 mm
     The construction speed: 1800 mm/min
     Move speed: 1.2 mm/min
     Deposition rate: 33 cm/h
     Movement: X and Y axis and Z axis of the low friction liner, X and Y is linear bearing.
     All welded with built-in microSD card slot for the independent electronic printing.
     Enhanced calendar, and improve the assembly of X and Y axis is  convenient
     Ultra-low print noise, allows you to print more quiet!
     The machine shipment include: the machine packing size: 420x420x510mm weight 6.6 KG
     1, and a printer
     2, a switch power supply 24 v
GMT+8, 2026-7-1 18:27 , Processed in 0.075570 second(s), 9 queries , Apc On.
