查看: 4735|回復: 3
today ,I want to sell delta 3d printer
發表於 2014-8-13 11:11:56 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
DLT -180 Delta3d printer Open source 3 d printers The completeTechnical parameters:
1, the printing technology: the accumulation of fused deposition molding (FDM)
3, overall dimensions: height:600 mm  width:320 mm   length:320 mm 4, the total weight: 10 kg (including packaging)
5, external frame: imported aluminum, steel (laser precision cutting)
6, extruder:remotely and  high-speed extrusion machine
7, the print head material: copper, aluminum, polyether ether ketone material forming
8, nozzle diameter: 0.4 mm (18, J - head hotend)
9 nozzle number: single nozzle
10 and the data format: STL
11, software: Repetier host
12, print range: 160 mm diameter     hight  230 mm
13, power input: AC110-220 - v
14, the power supply output: DC 12 v 7 a
15,print plate: high borosilicate glass    180 mm in diameter
16, synchronous belt wheel / 16 teeth, belt GT2
17, equipped with LCD screen
The performance parameters
1, print thickness of 0.05 mm to 4 mm
, 2, mechanical precision is 0.0125mm
3, the operating system, Windows/Mac/Linux
, 4, high-speed USB device interface or SD card
Shipping list:
1, 3 d DLT - 180 delta printer (fully assembled)
2, the power supply 1 (12 v 7 a)
3,USB cable 1
4 blue import 3 m adhesive tape (mesa print use, prevent deformation)
5, He3D material frame 1
6, print the test material to 100 grams
 樓主| 發表於 2014-8-15 10:45:52 | 只看該作者
The price is $420
 樓主| 發表於 2014-8-27 11:30:38 | 只看該作者
Today's activities!!!!!!!!!!!Delta 3 d printers, promotional activities,
group buying the cheapest!Welcome to snap up!
buy:http://www.reprap.cn/he-3d-the-c ... inter-kit-p-85.html
skype:reprap.cn
 樓主| 發表於 2014-9-1 09:40:52 | 只看該作者
My life is like a 3 d printer in the print yes repeated movement, although boring, stand still, but I can keep at it!Because my life is like a printer, as long as the efforts to insist, adhere to the effort, will have a great future!Yeah!
GMT+8, 2026-10-3 08:38 , Processed in 0.174287 second(s), 8 queries , Apc On.
