查看: 4738|回復: 0
Straight down $144 of Mendel 3 d printers
發表於 2014-8-15 10:43:14 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
He3D-B300 3D Printer Whole Machine Reprap
The size of Reprappro Mendel is increased
1, 5 mm thickness aluminum alloy table, more durable, heat up more faster
2, extensibility, scalable single nozzle design (standard for the print heads, already reserve the installation position)
3, FT card offline print function, this card is the same  memory card in the phone
4, install a Melzi Ardentissimo electronic circuit (for details, please refer to  electric and electronic parts catalog of our store)
5,  for 1.75 mm filament (PLA ABS)
6,more simplely and easily to assembly and  maintenance
7,linear bearings for X, Y, Z axis! Movement is more fluent, and more accurate.
8, printing precision is improved, the nozzle diameter is 0.40 mm(if you need 0.5mm,please left message for us)
9. replacing materials is more quickly (you can change different color materials, to achieve colorful model, for details, please refer to the beblow picture)
10,  printing size is increased, do not worry about a bigger model.
11, the power is 24 v, 400 w, support 110 v to 220 v
GMT+8, 2026-10-3 12:02 , Processed in 0.357235 second(s), 8 queries , Apc On.
