查看: 4900|回復: 1
He3D-A140 3D Printer kit Huxley Reprap
發表於 2014-9-2 12:22:09 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
Products Description:
Attention: This product is kit package ,need assemble .Thanks .
3d printer Motherboard: melzi main chip 1284 p
3d printer stepper motor A4982 chip
Output power: 24 v input  AC110-220 - v
Print the most large area: 140 x140x110mm
Physical size: 260 x280x280mm
Printing material: ABS, PLA, 1.75 mm in diameter.
Building surface: PCB heating bed, aluminum mesa, in order to reduce the complexity of the assembly, to ensure parts deformation.
nozzle diameter:0.4mm (if you need 0.5mm, please left a message for us)
Precision standard: 0.1 mm
Resolution: 0.0125 mm
Construction speed: 1800 mm/min
Move speed: 1.2 mm/minute
Operation systerm support: Linux  Mac  windows7 or later   XP
Printing software: Repetier Host or Pronterface
Deposition rate: 33 cm/hour
Movement: X and Y and Z axis low friction bushing, X, Y is linear bearing. All welded electronics and built-in microSD card slot for independent printing. Enhanced set, improve the X and Y shaft assembly is convenient Ultra-low print noise, let you print more quiet!
Contain all parts for assembly .
1, 1 pack hardware fittings
2, 5 NEMA14 stepper motors
3, heating bed 1 set of components
4, extrusion units 1 set
5, RP plastic parts 1 bag(total 42 piece. 2 metal coupling)
6, power supplier 1
7, 1 piece motherboard
Besides, we will give you 100g ABS , a set of special little tools and 1m high temperature tap as gifts . Thanks .
 樓主| 發表於 2014-9-3 15:38:29 | 只看該作者
It's only $299
GMT+8, 2026-10-3 02:59 , Processed in 0.128848 second(s), 10 queries , Apc On.
