查看: 5582|回復: 0
He 3D - The Complete Open Source Delta 3D Printer Kit
發表於 2014-9-19 10:43:59 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
He 3D - The Complete Open Source Delta 3D Printer KitProduct Description
If you need to purchase a complete assembly of the product, please click the image below
Technical parameters:
1, the printing technology: the accumulation of fused deposition molding (FDM)
3, overall dimensions: height:530mm width:230 mm length:290mm 4, the total weight: 10 kg (including packaging)
5, external frame: imported aluminum, steel (laser precision cutting)
6, extruder:remotely and high-speed extrusion machine
7, the print head material: copper, aluminum, polyether ether ketone material forming
8, nozzle diameter: 0.4 mm (18, J - head hotend)
9 nozzle number: single nozzle
10 and the data format: STL
11, software: Repetier host
12, print range: 160 mm diameter hight 230 mm
13, power input: AC110-220 - v
14, the power supply output: DC 12 v 7 a
15,print plate: high borosilicate glass 180 mm in diameter
16, synchronous belt wheel / 16 teeth, belt GT2
17, equipped with LCD screen
The performance parameters
1, print thickness of 0.05 mm to 4 mm
, 2, mechanical precision is 0.0125mm
3, the operating system, Windows/Mac/Linux
, 4, high-speed USB device interface or SD card
Shipping list:
1, 3 d DLT - 180 delta printer (the kit)
2, the power supply 1 (12 v 7 a)
3,USB cable 1
4, print the test material to 100 grams
complete tutorial DVD + + video tutorial +software+ PDF tutorial
Packaging DetailsUnit Type:piecePackage Weight:8.500kg (18.74lb.)Package Size:65cm x 30cm x 32cm (25.59in x 11.81in x 12.60in)
GMT+8, 2026-10-3 12:02 , Processed in 0.178553 second(s), 8 queries , Apc On.
