查看: 5104|回復: 0
HE3D- DLT -180 complete assembly Delta 3d printer Open source
發表於 2014-9-19 10:46:13 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
Product Description
Technical parameters:
1, the printing technology: the accumulation of fused deposition molding (FDM)
3, overall dimensions: height:720 mm  width:430 mm   length:430 mm4, the total weight: 10 kg (including packaging)
5, external frame: imported aluminum, steel (laser precision cutting)
6, extruder:remotely and  high-speed extrusion machine
7, the print head material: copper, aluminum, polyether ether ketone material forming
8, nozzle diameter: 0.4 mm (18, J - head hotend)
9 nozzle number: single nozzle
10 and the data format: STL
11, software: Repetier host
12, print range: 160 mm diameter     hight  230 mm
13, power input: AC110-220 - v
14, the power supply output: DC 12 v 7 a
15,print plate: high borosilicate glass    180 mm in diameter
16, synchronous belt wheel / 16 teeth, belt GT2
17, equipped with LCD screen
The performance parameters
1, print thickness of 0.05 mm to 4 mm
, 2, mechanical precision is 0.0125mm
3, the operating system, Windows/Mac/Linux
, 4, high-speed USB device interface or SD card
Shipping list:
1, 3 d DLT - 180 delta printer (fully assembled)
2, the power supply 1 (12 v 7 a)
3,USB cable 1
4, He3D material frame 1
5, print the test material to 100 grams
If you assemble it by ourselves, please buy bulk package, click on the image
GMT+8, 2026-10-3 07:18 , Processed in 0.155267 second(s), 8 queries , Apc On.
