查看: 7436|回復: 0
He3D-tricolor2 3D printer kit reprap bigger size
發表於 2014-10-7 15:26:13 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最後由 he3d 於 2014-10-7 15:27 編輯
Products Description:
if  you want to buy the whole machine,we can assemble it for you.but you need add 300usd,In addition,we will send you 3 material supports,and 1kg ABS filament for free.
Printing size is about:250x230x140mm
external dimension:470*450*400mm
Nozzle quantity: three pieces(nozzle diameter:0.4mm  if you need 0.5mm,please left message for us)
Off-line printing: support (master board can carry TF card)
Control master board: Melzi (two pieces) master and slave board
Printing material: ABS, PLA, 1.75mm
Nozzle temperature:0-260°
Computer interface: USB
Precision standard: 0.1-0.4 mm
Resolution: 0.0125 mm
Construction speed: 1800 mm/min
Move speed: 12000 mm/minute
Deposition rate: 33 cm3/hour Movement: X and Y and Z axis is linear bearing.
Power: Input AC110-230V, Output DC 24v 400w
Package weight: 10kg (wood packaging box)
Size after packaging: 530*230*290mm
Characteristics of fantastic three colors』 printing 3D print:
1.  support three different material to print, for example PLA, ABS, PVA(realize special support material to print, PVA)
2. three different colors』 material
3. change different diameter nozzle, to realize different thickness of layor printing, big nozzle satisfy inner filling, small one satisfy out printing
4. 5 mm thickness aluminum alloy surface temperature, durable heat up faster
5. during print lower sound
6. support component printing, to reduce the edge warping phenomenon the kit parcel
It is recommended that at the same time buy:
3 pcs ++3 pcs
Customers Who Bought This Product Also Purchased...
GMT+8, 2026-10-3 05:17 , Processed in 0.145810 second(s), 8 queries , Apc On.
