查看: 2992|回復: 0
Sensor 傳回比較的問題?
發表於 2014-11-21 12:14:38 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最後由 havy 於 2014-11-21 12:17 編輯
Sensor 傳回比較的問題?
目的:由電壓及電流讀取值;然後換算為功率(P=I*V),程序碼如下~
問題:sensor 回傳的值沒問題;換算丟入P0&Pn 值沒問題<==serial monitor 觀查皆正確。
             執行上卻沒有辦法得到if 判斷條件(因為P0&Pn改變皆是同時的)後執行PWM+-結果.請教各位大神,幫忙檢視程式碼那裡寫錯了…謝謝
========Code================================
float P0 = 0;
float Pn = 0;
int pwm=9;           // pwm output to mosfet
TCCR1B = TCCR1B & 0b11111000 | 0x01; // setting prescaar for31.372KHz pwm
Serial.begin(9600);  // Openserial communications and wait for port to open:
pinMode(pwm,OUTPUT);
int P[5],i,d;
float pwm_d=0;
intsensor1 =analogRead(0);
intsensor2 =analogRead(1);
float Solar_volt = sensor1*25/1024;
float Solar_curr = 0.0488281*sensor2-25;
analogWrite(pwm,127);  //set 50%Duty ration for MOSFET switch
Serial.print("Duty ratio is 50%");
P0= Solar_volt*Solar_curr; //read P0
for(i=0;i<5;i++)
   P=P0;
   if (P!=P0)
     Pn=P;
while(P0<Pn)
   for(d=127;d<=179;d++)
   analogWrite(pwm,d);
   delay(100);
   if(P0 == Pn)
     analogWrite(pwm,d);
     pwm_d=d/256*100;
     Serial.print("Duty ratio is=/n");
     Serial.println(pwm_d);
     Serial.print(P0);
     Serial.print(Pn);
while(P0>Pn)
   for(d=179;d<=0;d++)
   analogWrite(pwm,d);
   delay(100);
   if(P0 == Pn)
     analogWrite(pwm,d);
     pwm_d=d/256*100;
     Serial.print(P0);
     Serial.print(Pn);
GMT+8, 2026-10-3 07:36 , Processed in 0.157101 second(s), 7 queries , Apc On.
